rebuilding a dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2010, 12:49 PM   #1
2fst4you
2fst4you's Avatar
Default rebuilding a dana 44
how much am i looking at spending to get my dana 44 rear axle fitted with all new bearings, a new carrier and the gears set up?
its for a 02 wrangler
Old August 20th, 2010, 12:54 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
What gear ratio?
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old August 20th, 2010, 01:12 PM   #3
2fst4you
2fst4you's Avatar
3.73s which i already have
Old August 20th, 2010, 01:24 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
You already have the gears, or you're replacing the 3.73 with new ones?
What's wrong with the carrier? Are the spider gears okay? (matters for parts pricing).
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old August 20th, 2010, 04:52 PM   #5
2fst4you
2fst4you's Avatar
I have the 3.73s and a aussie locker that I need installed in my dana 44 with all new bearings that's are needed. B/c the locker u don't need the spiders correct? And the carrier is weak b/c someone destroyed a spider gear prior
Old August 20th, 2010, 04:58 PM   #6
xj4life
xj4life's Avatar
I'd say just give Kevin a call at Jeeperz Creeperz directly and he'll be able work through it with you
Old August 20th, 2010, 05:09 PM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
pm sent
H.o.r.e
Old August 21st, 2010, 12:56 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Just curious, but what happened with this:
so i got my axle done...costed $312 and had all new bearings put in as well as a new pinion seal and flange. The labor was only $155 and the parts they put in were around $145
Discount job gone wrong?
Old August 23rd, 2010, 01:21 PM   #9
2fst4you
2fst4you's Avatar
no that was for my front axle the d30 this is for my rear the d44
Old August 23rd, 2010, 01:36 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Oh, I was confused by the first post in the thread:
Im going to be buying a locker for my dana 44 and need that and my 3.73 gears installed in that and my dana 30.....
where should i go to get this done? and im only 18 so price is a concern
thanks,
Cameron
I'd say you'd be looking at $550-$600 for parts/labor, roughly.
Old August 23rd, 2010, 02:44 PM   #11
joe_jeep
welfare wheeler
joe_jeep's Avatar
kevin at jeepers creepers is the man!
go drop your jeep off with him. he will call you when its done!
problem solved.
Old August 23rd, 2010, 11:54 PM   #12
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Is this price for a rebuild kit and the install? That seems a little high to me. Considering most Master install kits are less than $200. So labor would be $350-400??
He already has the gears and locker, but I think you may have included these parts in your quote.
Old August 24th, 2010, 11:55 AM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Yes, I did. This thread confused me
Old August 24th, 2010, 02:55 PM   #14
joe_jeep
welfare wheeler
joe_jeep's Avatar
he has done 2 ford 9 inch rears for me. the price was untouchable!
go check out his shop its a nice place, you will buy all kinds of stuff while your there.
he has a pretty good inventory.
Page generated in 0.38502 seconds with 65 queries
