Great Lakes Spa *** sold!!!*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2010, 09:01 AM   #1
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Default Great Lakes Spa *** sold!!!***
I'm selling my demo spa in-leu of upgrading to a little bigger model.
It's a 2006 GL5 (5 person spa) that is prestine.
Silver metallic shell with gray woodgrain (EON synthetic) sides. New, this unit was about $7K with the included options
This unit has seen very little use.
$2800.00 obo
Included options:
Ozonator
LED lighting package (underwater LED and clear cup holders light up as well)
AM/FM/CD player/ MP3 input player with 2 coping speakers
Cover (4"-2" taper)
Cover handling device.
Measurements are 78" x 78" and 31" tall without the cover installed.
it requires a lever cement slab or reinforced deck since it will end up weighing about 5K lbs once you have it filled with water and people.
also a 50 amp GFCI wiring. (you electrician can quote that out for you.)
Now for the important stuff- like pics:
Also- here's the manufacturer's link: http://lifeisgreatlakes.com/gl5.html
SANDVIPR is offline
Old August 20th, 2010, 09:04 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Are you sure about the 5,000 pounds?
clarkstoncracker is offline
Old August 20th, 2010, 09:07 AM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Pretty close. That's what we tell pretty much any customer.
Empty spa-500 lbs
350 gallons of water @ 8 lbs per gallon
4 people @ 200 lbs each....
And add a grill, a couple more people standing around, and anything else you may have on your deck and you can easily exceed 5 or 6K.
SANDVIPR is offline
Old August 20th, 2010, 09:09 AM   #4
clarkstoncracker
lol
Empty spa-500 lbs
My deck has a spot for a spa and I was told it would only support 3800-4200 pounds.. argh...
I have tables, chairs, a grill, and other stuff, but it wouldn't even be on the same level at the spa itself. Do you have a weight on the spa, not figuring in random people standing around?
Old August 20th, 2010, 09:15 AM   #5
DuffMan
Your Message Here
DuffMan's Avatar
Spa that size is likely to be about 425 gallons - at 8.35 pounds per gallon, that's 3500+ pounds of water. Another 1500 for the tub itself seems a little high, so maybe 4200-4500 pounds.
The tub I just replaced seated 8 and ran 570 gallons. When they picked it up (I traded it in) it flattened the tires of the trailer/dolly rig they use to haul them on. The wood frame and housing, huge tub assembly was pretty heavy - I'd say it ran over 5000 lbs (full) easily, since the water would go 4700 lbs itself.
DuffMan is offline
Old August 20th, 2010, 09:21 AM   #6
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
OK- I double checked the brochure- 545 lbs. empty
capacity (due to the seating configuration) 360 gallons. (figuring 8 lbs per gallon)
total weight before people = 3425.
If you don't intend on having a 10 person orgy in it, you should be fine!
SANDVIPR is offline
Old August 20th, 2010, 11:22 AM   #7
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Did you pee in it?
BigBlockBlazer is offline
Old August 20th, 2010, 11:24 AM   #8
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Originally Posted by BigBlockBlazer View Post
Did you pee in it?
maybe????
SANDVIPR is offline
Old August 20th, 2010, 11:30 AM   #9
BigBlockBlazer
Axle breakin' 101
Nice unit, wish I had the extra bling.
Old August 20th, 2010, 11:42 AM   #10
clarkstoncracker
lol
I found one that I was going to buy, but it was three times what you're selling yours for. I'm going to have to look into it, now that I know the weight is what a normal tub is. Thanks
Old August 20th, 2010, 12:27 PM   #11
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Sweet! feel free to PM me anytime! I'll be busy Sat , but Sunday AM I usually check for things I missed.
SANDVIPR is offline
Old August 20th, 2010, 01:08 PM   #12
JeepInABox
In too deep
JeepInABox's Avatar
Who plans on a 10 person orgy, it just happens sometimes and you don't want to be a dick and tell them sorry my deck can only handle a 9 person orgy.
JeepInABox is offline
Old August 20th, 2010, 01:35 PM   #13
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Ah- you could probably get away with it- as long as everyone wasn't humping in the same direction at the same time...
SANDVIPR is offline
Old August 22nd, 2010, 09:11 AM   #14
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
ttt
SANDVIPR is offline
Old August 23rd, 2010, 02:39 PM   #15
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
ttt
SANDVIPR is offline
Old September 1st, 2010, 09:00 AM   #16
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
ttt Shoot me an offer!
SANDVIPR is offline
Old September 1st, 2010, 09:02 AM   #17
clarkstoncracker
lol
pm sent
Old September 1st, 2010, 11:07 AM   #18
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
PM returned!
SANDVIPR is offline
Old September 8th, 2010, 07:03 PM   #19
tonka toy
It's got a HEMI!
tonka toy's Avatar
Is it sunday yet
Thanks Tim the wife and I will put it to good use
tonka toy is offline
Old September 9th, 2010, 08:43 AM   #20
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
We'll mark this one as "SALE PENDING", but I would pretty much write this one off as "SOLD!"
THANKS TONKA!!!! ENJOY!
SANDVIPR is offline
Page generated in 0.42183 seconds with 83 queries
