SOLD - 1985 F350 Crew Cab, 4x4, Auto, Diesel - $1500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2010, 08:15 AM   #1
AZDIRT
How'd I End Up Here?
AZDIRT's Avatar
Send a message via AIM to AZDIRT
Default SOLD - 1985 F350 Crew Cab, 4x4, Auto, Diesel - $1500
SOLD - $1500, comes with all the parts I have in the garage (enough to fill the bed, and then some). Runs & drives great. Would be cost-effective tow-rig/work truck/hauler, just may need a little work.
6.9L HAS LOW OIL PRESSURE AT IDLE (this seemed to occur after changing the oil cooler, so in the meantime I will be changing out the oil cooler again, and Price may go up if I fix this problem)
Please Read On:
All new driveline joints (frt & rear), hydroboost brake system from F450 installed (braking power is AMAZING), new brake pads all around, new wheel bearings in front. New water pump, fan clutch, brakes, rebuilt oil cooler, Alpine stereo, new headliner, newish Dual Optima Yellow top (deep cycle and starting) batteries, comes with new starter (spare, didn't need it), headlight relay upgrade, running light relay upgrade, all new Beru glow plugs, comes with a set of remanned BB code injectors (has remanned AA injectors in it now), remanned injector pump (not sure on mileage on pump and injectors in motor). New driver side door seal. Has new ISSPRO pyrometer. Fancy Alpine head unit and Alpine door speakers.
Also comes with two fuel tanks with known-good sending units, the rear is a plastic high capacity. Comes with two new Ford-supplied front doors with good weatherstrip and new towing mirrors. Comes with a newer style combination fuel filter/water seperator to replace the two seperate systems on the truck. Comes with a good spare injector pump and hard lines. Comes with good passenger side door weatherstrip.
Comes with 6" lift kit (blocks & shocks for the rear, new springs and drop barckets for the front, drop pitman arm, drop crossmember). ALSO comes with a full set of F450 springs: I left the shackles and frame brackets on the springs because they fit the frame on this truck. Also comes with the overloads and frame bump stops for them (also off of the F450). COmes with a decent vynil front seat, same color as existing interior. Spare radiator. Spare air cleaner assembly. Spare set of door hinges with tight bushings. Comes with all F450 badges if you want to get creative. Come with spare oil cooler. Comes with spare set of BERU glow plugs. Spare CDR valve. Comes with engine glow plug harness and new controller from an 87-up truck, this is a great upgrade. Comes with a set of 4 load range E tires with 65-70% tread and no weather checking. Also comes with set of 6 dually tires and wheels, if you wanted to make it a dually. I also have a set of dually wheel hubs that would fit the D50 or a D60 (if you swapped one in).
ALSO- I will throw in a D60 Front axle with 3.73 gears, King Pin, and set of 4.11 gears for $500 if you buy the truck. This would be a direct bolt in since it is from a early 90s F350.
Please call as there is definitly stuff I am missing.
You can start, run, and drive this truck no problem, but oil pressure is low at idle. Has compression in mid to upper 400s. Has either 125 or 225 on the clock, which is confirmed by condition of drivers seat and pedals. Truck is painted black with tractor supply equipment enamel. All body mounts are solid, floor is solid. Some rust on pass rear rocker, some rust on front fenders, a little over rear wheel wells. Interior is good for the age, seats are a little stained but may come clean. Alignment is good, steering is pretty tight, does NOT go through tires.
C6 Auto w/ 4.11 gears
This deal might not last, if I end up finding a motor for it or fixing it. In the mean time I will be changing the oil cooler again. If I fix the low oil pressure issue, price will go up.
AZDIRT is offline
Old August 18th, 2010, 08:56 AM   #2
RangerXtreme
pm sent
RangerXtreme is offline
Old August 18th, 2010, 09:07 AM   #3
AZDIRT
AZDIRT's Avatar
PM Returned.
ALSO - Forgot to mention it had all new tie rod ends and ball joints 2-3 years ago.
AZDIRT is offline
Old August 18th, 2010, 09:20 AM   #4
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Dang, great deal.
RIP FULLSIZE4LIFE
SHARPMACHINE is offline
Old August 18th, 2010, 10:24 AM   #5
mudbillyredneck
mudbillyredneck's Avatar
I had my hands on that truck for awhile...was a good driver back then
The Front steering is all moog stuff.
I replaced everything right before the sale ( it was my winter project)
....so however many miles AZDIRT has put on it is how many are on the brakes and steering components
It was a very nice condition truck, which is why I sold it to someone up north...I couldnt bring myself to driving it in the salt
mudbillyredneck is offline
Old August 18th, 2010, 10:53 AM   #6
AZDIRT
AZDIRT's Avatar
It has been a good truck. I've put 20,000 or so miles on it in the last 2-3 years, mostly longer trips hauling something or other.
I would keep it and fix it myself, but I already picked up a powerstroke truck.
AZDIRT is offline
Old August 18th, 2010, 11:00 AM   #7
mudbillyredneck
Any trades ?
I have 44's , also have a nice set of superduty " WELD " rims
Old August 24th, 2010, 01:37 PM   #8
AZDIRT
AZDIRT's Avatar
Sold!
AZDIRT is offline
Page generated in 0.30571 seconds with 47 queries
