axle upgrade help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2010, 04:04 PM   #1
PatsCJ7
Default axle upgrade help
i have a ford 9 in with 4:10 gears in the rear of my cj7. It is about 60 inches from backer plate to backer plate.
Currently my front is a dana 30 with 2 inch wheel spacers on it. i am lookin for a dana 44 or something a little stonger and a little wider so i can do away with the wheels spacers that will work up front that has a passenger side drop
The jeep is locked front and rear on 35 in boggers. Also is is sprung over.
If you have anything that will work for me let me know
PatsCJ7 is offline   Reply With Quote
Old August 17th, 2010, 04:41 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Can make a chevy 44 narrowed to ~61" wms that will bolt in SOA using two stock length shafts otherwise a pre 80 waggy 44 or Scout 44 will need the springs outboarded but are the right width.
Old August 18th, 2010, 04:13 PM   #3
PatsCJ7
Thanks alot for the info so if anyone has one of these axles or knows where i can find one let me know because im tring to get this done before labor day weekend
Does anyone know if you can change a chevy dana 44 over to a 5 on 5.5 bolt pattern ? is is possible to weld the wheel stud holes shut and re drill them to 5x5.5 ?
Old August 18th, 2010, 04:30 PM   #4
PavementPounder
PavementPounder's Avatar
He said it was 60" between the backing plates, so he must have a 9" out of a full-size Ford truck. Those axles won't be wide enough. i think he's in 65" front axle territory.
Yes, with store-bought factory parts. Do some searches in the Tech Forums here - I know it has been posted. otherwise, you should be able to find the parts list rather quickly with Google.
Old August 19th, 2010, 03:56 PM   #5
PatsCJ7
The fore 9in in the rear came out of a 60's ford f100.
Its not as wide as a full width. its about 4 inches wider than a cj widetrack
Old August 19th, 2010, 04:35 PM   #6
PavementPounder
CJ WT's D30 fronts are ~56" WMS. With 2" spacers on each side, it would about match a 60" WMS rear axle. The problem here is that the dimension you gave us for your 9" rear was 60", but you said that was the distance between the backing plates and not between the wheel mating surfaces.
An F100 was a full-size 2wd, correct? I did some Googling and everything I'm reading is saying that the 60's F100 WMS is in the area of 67". We need you to give us the distance of your 9" wheel mating surfaces (where the wheel touches the drum) before we can make any good or accurate recommendations.
Page generated in 0.20268 seconds with 41 queries
