Id this TTB lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2010, 01:40 PM   #1
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Default Id this TTB lift
Anybody know which brand of lift I've got here. It uses these drop brackets up front with 4" blocks for the rear. Springs and all are black but I'm not sure that they have always been black.
Troll53 is offline   Reply With Quote
Old August 17th, 2010, 01:50 PM   #2
Looks like maybe superlift? Its a. Better kit, as it has a full drop bracket for pass side beam vs just a drop plate like the cheaper kits offer
Old August 17th, 2010, 02:06 PM   #3
Troll53
Troll53's Avatar
So, it was worth the $350 I paid for the whole rig then? Thanks John.
Old August 18th, 2010, 07:42 AM   #4
95geo
newbie
95geo's Avatar
yes, what are you going to do with it?
Old August 18th, 2010, 08:04 AM   #5
Troll53
Troll53's Avatar
I plan on using it! Just wanted to know what brand I'm dealing with should I end up needing a part. Of course I'm probably being overly cautious. I mean, things never break when you're out beating on a lifted vehicle!
Old August 18th, 2010, 08:49 AM   #6
95Bronco
What year truck is that?
Reason I ask is most TTB's I've seen have the swaybar mount built into the lower spring seat. The brackets on the beams themselves looks like it would work better (and make fabbing disconnects much easier)
As for the lift, I think it's a rough country. Their radius arms drop brackets look like those.
It's definitely not a superlift unless they changed their design at some point.
here is a picture of the superlift brackets.
http://broncograveyard.com/images/ca...FRNTBRACKT.JPG
95Bronco is offline   Reply With Quote
Old August 18th, 2010, 09:56 AM   #7
Troll53
Troll53's Avatar
The truck is an 86 Bronco II. The previous owner built home-brew disconnects already. Suspension-wise the truck is already fairly well built and the body is solid with the exception of the doors. It's getting a 4.0, D35/8.8, 4.56:1 gears, and lockers.
The pictures provided on the web are not all that great. Even the manufacturers sites are not very good. I'm convinced it is not a Skyjacker, the passengers side bracket does look very close to a Superlift with the two-position drop locations. I'll have to look at the Rough Country lifts again. Thanks for the feedback.
Old August 18th, 2010, 11:54 AM   #8
Superlift changed there design a few years back as did rough country. Rough country only used drop plates a few years ago. I believe the have done away with the plates since.
Old August 18th, 2010, 12:15 PM   #9
Troll53
Troll53's Avatar
Just looked at the Rough Country site and their drop brackets looks like it has only one hole for the pivot. The only one I've seen that has two positions for the pivot is Superlift. It might be a mixed lift I suppose but, the thing seems to be too clean for the previous owner to have just cobbled something together.
Old August 18th, 2010, 01:32 PM   #10
They are probably old ass brackets and have since been redesigned. That's why. You can't. Finf the matching image.
Old August 18th, 2010, 01:46 PM   #11
Troll53
Troll53's Avatar
Probably right.
Page generated in 0.30942 seconds with 56 queries
