How this pattern am look - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2010, 11:40 PM   #1
dune coon
do work
dune coon's Avatar
Default How this pattern am look
I used Scooter's recent post for guidance, but I figured I could use some expert opinions here...please chime in with your input. I know this pattern is shallow...but backlash is currently at 0.008 - won't that decrease quite a bit when I shim the ring gear side?
For reference - this is a D60 HP 5.13 gearset, new install. These pictures are my first setup.
What's the best way to get a clearer pattern - I see on Scooter's pics, it stands out much more than mine.
dune coon is offline   Reply With Quote
Old August 17th, 2010, 09:01 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
You don't have shims on both sides of the differential?
Old August 17th, 2010, 09:11 AM   #3
95geo
newbie
95geo's Avatar
Use a piece of wood between the housing and the ring gear/carrier to create some drag so you get a more defined wipe of the gear teeth.
You have to set the backlash every time you adjust the pinion depth. Get the right amount of spacers to get a tight slip fit for the carrier into the bearing caps, once you have the numbers for each side figured out then you work on getting the pinion depth correct.
By the looks of it, you need more work on the pinion depth before getting the backlash narrowed down any more.
Dont forget the proper bearing preloads (pinion most importantly) while you are doing all of the setting up or your pattern will change drastically.
Old August 18th, 2010, 12:22 AM   #4
dune coon
do work
dune coon's Avatar
cool...thanks to both of you for the tips. I tore it down and set it back up 7 times, now I've got perfect bearing loads, 0.008 backlash, and a sweet looking pattern
Page generated in 0.18963 seconds with 35 queries
