need help identifing an axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2010, 08:12 PM   #1
muddcherokee_09
jeeper for life
muddcherokee_09's Avatar
Default need help identifing an axle
it came out of a 1981 ford f-250 custom pickup truck it is a one ton axle and that is all i know
muddcherokee_09 is offline   Reply With Quote
Old August 16th, 2010, 09:33 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
front or rear
Old August 16th, 2010, 11:03 PM   #3
stockholm_steve
stockholm_steve's Avatar
I would guess it's a rear axle since Ford didn't go back to a straight axle up front till '86. Question is, are you saying this axle was swapped into an F-250 from a F-350? Depending on the year, your choices are Dana 60, Dana 70 or 10.25 Ford or Sterling.
edit: If you are talking about a straight front axle your options are D50 or D60... just wanted to cover all the bases.
stockholm_steve is offline   Reply With Quote
Old August 17th, 2010, 12:42 AM   #4
bigblockford79
Big Block Ranger
It will be a Dana Axle, the sterling(Ford) axle didn't show up until 1985.
Most dana axles can be easily identified buy looking at the differential casting, there will be a number cast into the webbing. it is usually on the front, drivers side in the section under the axle tube.
Old August 17th, 2010, 07:48 AM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
If it's the D61 take it in for scrap.
Old August 17th, 2010, 09:36 AM   #6
PavementPounder
PavementPounder's Avatar
Let us know when you know something else.
Old August 17th, 2010, 09:46 AM   #7
Wheelman
Extreme Mudder
Wheelman's Avatar
Dana 60 The 70 wasn't used until 1983 And the 10.25 ford in 1985.
Front would be a Dana 44 or 50
Wheelman is offline   Reply With Quote
Old August 22nd, 2010, 06:09 PM   #8
muddcherokee_09
jeeper for life
it is a dana 60 with 3.54 gears i am looking to swap for a 14 bolt and or sell it outright
Old August 22nd, 2010, 06:21 PM   #9
kkodet
kkodet's Avatar
Um, incorrect on many levels. The Dana 70 was used all the way back into the 1960's, I just got rid of a 23 spline one with a 1968 date code, and I've had several dually 70's F-350's with dana 70 rears. As for the front, Ford discontinued front solid axles for the 1980 model year. (79 being the last) and then they came back in July of 1985 in the F-350 only until the F-250 superduty came out.
The front from 1980-june1985 would be a TTB dana 44 or 50, but nobody considers those real axles
Page generated in 0.30887 seconds with 50 queries
