CJ: Getrag( NV) 282 behind a 225? please respond - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2010, 09:10 PM   #1
cerial
1200PSIg Double acting
cerial's Avatar
Default Getrag( NV) 282 behind a 225? please respond
Has anyone put a Getrag / Muncie(NV)282 behind a 225 dauntless in a cj-5?
Please read this entire post before criticizing. I know it sounds nuts just look at the numbers.
It is the 5 speed manual they used in the v6/v8 Fiero's as well as tons of other cars and is the grandfather of what is used in many gm cars today.
* 1st gear: 3.50:1
* 2nd gear: 2.05:1 (MG1: 2.19:1)
* 3rd gear: 1.38:1
* 4th gear: 0.94:1
* 5th gear: 0.72:1
* Reverse: 3.41:1
* Final drive ratio: 3.61:1
Compare it to the 3 speed
3.33:1, 1.55:1, 1:00:1, Rev 4.53:1
Yes it is a transverse transmission I would use a small shaft to a 241/300.
Running the stock axles(want it to look stock) and I think it will save about a foot in drive-line length(or more)and that is a huge difference when your talking a cj5.
Long story short running the stock axles(4.10). 31 inch tires and the dana 300.
using this site. Gear Ratio Calculator to get the numbers below.
Top gear
the 3 speed at 2250 rpm= 51 mph
the 5 speed at 2250 rpm= 70 mph
The 3 speed at 3250 rpm= 73 mph
The 5 speed at 3250 rpm= 102 mph
Has anyone done it before if so what did they have to do? Will it work if not why not.
I am looking at a cj5 on Saturday. While I see myself rebuilding the 225 with mild mods I don't see using the 3 speed transmission. But after looking for other transmissions(non-electronic). I end up having the drive-line just to long. I looked at 4 speeds and then 5 speeds still to long after the transfer case. So I peeked at transverse setups and this looks like it will work nicely.
Thank you
Old August 12th, 2010, 10:18 AM   #2
PavementPounder
PavementPounder's Avatar
What torque rating does that transmisison carry?
I wasn't aware of any factory V8 Fieros. Thought they were all I4 or V6, which is why I ask about the rating.
Old August 12th, 2010, 10:20 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
Fiero's only came with the 2.5 and 2.8L, never a v8.
Old August 12th, 2010, 10:29 AM   #4
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
GM did have a few built with a 3.8 grand national motor, they decided it was a bit to much hp. Prototype shop built them for gm.
I think several people have put v8's in front of the manual fiero trannies? Look at a couple fiero forums?
Keep us informed about the build, sounds interesting.
RIP FULLSIZE4LIFE
Old August 12th, 2010, 11:04 AM   #5
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
I saw a couple of them a few weeks ago at the GM Tech Center car show. One of them had a Northstar V8 in it.
Red68Camaro is offline   Reply With Quote
Old August 12th, 2010, 05:25 PM   #6
Muttly
Muttly's Avatar
How are you going to get this:
To bolt up and work?
this thing is a transaxle with left and right axle shafts.
CJ's with 225 dauntless are typically older with the dana 18 case and offset rear axles, why not run the 18 and a saturn overdrive?
Muttly is offline   Reply With Quote
Old August 12th, 2010, 05:43 PM   #7
PavementPounder
I had a 225'd CJ with a Ford RUG 4-speed, Dana 18 and a Saturn OD. Still have the trans & bell, too. Maybe that could be a possible solution for you.
Old August 12th, 2010, 06:59 PM   #8
cerial
cerial's Avatar
Yea was referring to the 3.8 in the fiero there was tons of kits to adapt them.
I looked at the gear vendors and some ranger (early version of the gear vendor)like thing then dismissed the idea of a overdrive.
I totally forgot about the Saturn overdrive that's what I am going with. This is quite embarrassing actually.
Tags
5 speed, cj5, dauntless, stick
Page generated in 0.23253 seconds with 47 queries
