Clarion In Dash, TouchScreen 7" TV/DVD player - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2010, 01:57 AM   #1
dragthepaint
dragthepaint's Avatar
Default Clarion In Dash, TouchScreen 7" TV/DVD player
Selling my in dash, works fine just need some cash for a new project
7" Screen, DVD player, Touch Screen, Ipod interface, Navigation ready, it a awesome unit with lots of features
Asking $250
Features
Motorized 7" Touch Panel TFT Display: The Clarion MAX675VD is a double-DIN DVD Multimedia Station with a 7" TFT wide screen display and touch panel controls. The monitor has a resolution of 480 x 234 and 336,960 total pixels. The screen is motorized, and will slide out and down for easy loading and ejecting of your DVDs and CDs.
Touch Panel Controls: This unit has touch panel controls with interactive video graphics, making menu navigation easy. An on-screen numeric keypad allows you to directly access radio frequencies, and DVD/CD/MP3/WMA discs, chapters, folders, and tracks. The touch-screen surface is treated to resist dust and grime.
Display Angles: You can adjust the display's angle between 0 and 30 for better visibility. After the viewing angle has been set, the unit will return the display to that angle each time, even if the unit is turned off.
Dimmer Feature: When the orange/white illumination wire of this unit receives power (i.e. when you turn the vehicle's lights on), the display will change from the default day color to the default night color. You can independently adjust the brightness of the display with and without the vehicle's lights on.
3-Band Parametric EQ: This unit has a built-in 3-band parametric equalizer. You can make several adjustments to each band:
Bass:
Gain: -12dB to +16dB (in 2dB increments)
Center Frequency: 50Hz, 80Hz, or 120Hz
Q: 1, 1.25, 1.5, or 2
Midrange:
Gain: -12dB to +12dB (in 2dB increments)
Center Frequency: 700Hz, 1kHz, or 2kHz
Q: 1.5 or 2
Treble:
Center Frequency: 8kHz or 12kHz
Magna Bass EX: To emphasize the deep bass sounds, you can activate the Magna Bass EX effect. Allowing you to boost the ultra-low frequency range of your sound system with a center frequency of around 50Hz, this feature automatically compensates for the increased bass to eliminate any unwanted noise. M-B EX can be turned on or off in the menu.
Source Titling: Titles, up to 10 characters long, can be stored and recalled from memory for radio stations, TV stations, CDs, and individual discs in a connected changer. A maximum of 30 titles may be entered for the tuner mode, up to 15 titles may be entered for TV tuner mode, and up to 50 titles may be entered for CDs (played in the unit). In CD changer mode, you may enter 100 CD titles when using the DCZ625 or CDC655Tz.
Amplifier Bypass: You can bypass the built-in amplifier so the audio signal can be routed to an external amp in its purest state. This prevents any noise or distortion from being introduced by the internal circuitry.
Instant Station Recall (ISR): In addition to the 18 FM and 6 AM presets, you can preset a single favorite radio station to the ISR button. The Instant Station Recall feature allows you to access the preset station at any time, even if the DVD/CD player, CD changer, satellite radio receiver, or TV tuner is active.
24-bit D/A Converter: The unit's 24-bit D/A converter re-quantizes the 16-bit audio signals from CDs and DVDs as 24-bit data while maintaining the low distortion and high linearity of a 1-bit D/A converter. This allows an expanded dynamic range and clearer reproduction of subtle nuances, for a richer sound when viewing DVDs or listening to CDs.
MP3/WMA Playback: This unit can play MP3/WMA files recorded on CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, and DVD+RW discs in ISO 9660 Level 1 or 2 format. The maximum allowable number of folders is 255, and the maximum number of files allowable is 512 (max. 255 per folder). ID3 Tags (versions 2.4, 2.3, 1, and 1.1) will display the title, artist, and album information when recorded on the disc.
Dual-Zone Capability: The MAX675VD includes a 2-Zone switcher that allows rear seat passengers to enjoy a separate audio/video program on an optional rear monitor screen and wireless headphones (such as 020WH104), while the front seat passengers enjoy a completely separate source. Sources are selected on the face of the main unit. When the 2-Zone function is on, you can select internal sources (Tuner, DVD, Visual, iPod) and external sources connected via CeNET (CD changer, DVD changer, TV tuner, satellite radio tuner, etc.) for either zone.
CCD Camera Compatible: You can connect a compatible Clarion CCD camera (such as CK525E) to the CCD terminal on the back panel of the receiver.
Telephone Mute: This unit includes a triggered audio mute for cellular telephones. The brown wire in the supplied wiring harness must be properly connected in order for the receiver to mute when a cellular phone call is received. The telephone mute must first be activated in the menu.
DVD Controls
Touch Screen Controls: During DVD play, you can control the playback with a touch screen control pad. You can navigate through menus using on-screen "buttons", or directly select a chapter using an on-screen number pad.
Chapter Scan: This feature allows you to play the first 10 seconds of each chapter on a DVD.
Slow Motion: When playing a DVD, you may move forward through the program being played in slow motion. Slow motion playback cannot be performed in reverse.
Multi-Angle Display: This function allows you to choose the viewing angle of scenes that were shot from a number of different angles. Note: This function is limited to DVDs recorded with multiple camera angles.
DVD System Settings:
Display Size: allows you to select Full Wide (F.Wide), Cinema, Normal or Wide Mode for both 4:3 and 16:9 images.
Angle Mark Display: can be turned on or off. When this feature is turned on, an angle mark display appears on the screen for scenes that were shot at different angles.
Disc Menu Language: allows you to select English, French, Spanish, Chinese, Japanese, or Korean as the disc menu language
Audio Language: allows you to select English, French, Spanish, Chinese, Japanese, or Korean as the audio language
Subtitle Language: allows you to select English, French, Spanish, Chinese, Japanese or Korean as the subtitle language
Parental Lock:
Password: set the 4-digit password for enabling/disabling parental controls
Country Code: set the country code for parental controls
Parental Level: select the level of restrictions for parental controls
External Device Controls
iPod Ready: The MAX675VD can be used to control a connected Apple iPod. With an optional CCA649 iPod connecting cable, you can listen to, view, and control third generation (Version 2.2) and newer iPod units, including the iPod Photo, Nano, Mini, and fifth generation iPod video. If you wish to pass video from the iPod video units, the CCA673 cable will be needed instead. The MAX675VD provides a familiar touch sensitive control interface which looks just like the control pad and display of the actual iPod. While connected, the MAX675VD charges the iPod's battery. Note: First and second generation iPod and iPod Shuffle are not compatible.
Satellite Radio Ready: There are several options for connecting an optional XM or SIRIUS Satellite Radio receiver to this receiver:
XM Satellite Radio: To receive XM Satellite Radio, you can connect the optional CNP2000UC XM Mini Tuner and the CNP-CLA1 Clarion adapter cable (package item # 700XMCLA1).
SIRIUS Satellite Radio: To receive SIRIUS Satellite Radio, you can connect the optional SC-C1 SIRIUS Connect Universal Vehicle Tuner and the Clarion CLA-SC1 Ce-NET SIRIUS Satellite Radio interface (package item # 700SIRCLAR).
Auxiliary Input: A portable satellite radio receiver, such as the Delphi SkyFi3 or SIRIUS Sportster, can be connected to the head unit via an auxiliary input.
Note: A subscription is also required to receive satellite radio programming from SIRIUS or XM.
Navigation Ready: The Clarion NAX970HD Navigation System is easily integrated into the MAX675VD. You can view the navigation display on the monitor, hear the voice guidance commands through your speakers, and operate the navigation system using the front panel buttons.
CeNET Changer Controls: This unit can control compatible CeNET CD, MD, and DVD changers. Using an optional Y-adapter (item 020CCA519), this unit can control two CeNET changers.
Clarion CeNET TV Tuner Control: This unit is capable of controlling Clarion's TTX7501Z CeNET TV tuner. A total of 12 TV stations can be stored in preset memory.
Clarion CeNET Multi-channel Processor Control: This unit has a fiber optic output allowing you to connect and control (via a CeNET cable) the optional Clarion DVH940 Dolby Digital/DTS/Dolby Pro Logic II audio processor.
Inputs and Outputs Notes
Rear Panel Inputs and Outputs: In addition to the power harness and antenna connections, the unit features the following connections:
Fiber Optic Output: The unit has an optical digital output for connecting an optional compatible Dolby Digital/DTS decoder, such as the DVH940. (The Ce-NET cable also needs to be connected for control purposes.)
iPod Connector: The optional iPod adapters (CCA649, CCA670, or CCA673) connect to the head unit's round 10-pin DIN connector.
RGB Input: A round 8-pin DIN connector for integrating the optional Clarion NAX970HD Navigation System.
TV Tuner Input: A single RCA composite input for connecting a Clarion TV tuner.
DVD Changer Input: A single RCA composite input and proprietary DIN input for connecting a Clarion CD changer
Preamp Output/AV Input Molex Jack: A 20-pin harness with 12 RCA jacks plugs into this jack for the following inputs and outputs:
Preamp Outputs: The unit is equipped with three pairs of stereo female RCA jacks for connecting to external amplifiers (front, rear, non-fading).
Visual Input Terminal: For connecting an optional stand alone DVD or VHS player, the unit provides female RCA jacks for left and right audio and composite video inputs.
Visual Output: A single female RCA composite video output jack is provided for sending video signals to optional rear monitors.
2-Zone Output: A stereo audio output for 2nd Zone audio for connecting to an optional rear monitor
CeNET Terminal: A square multi-pin jack allows you to connect a Clarion CeNET DVD or CD changer, audio processor, TV tuner or Satellite Radio receiver.
dragthepaint is offline   Reply With Quote
Old August 12th, 2010, 01:16 AM   #2
dragthepaint
Solldddd
Page generated in 0.40848 seconds with 29 queries
