Full Size Broncos - front axles - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2010, 02:20 PM   #21
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Originally Posted by big_ol_bronco78 View Post
if you don't plan on running bigger than 33, i'd personally just do body lift, keep suspension stock
After redoing my Flareside, I will never put a body lift on this model Ford again(bronco or f150) if it is to be used in Michigan during the winter.
I could show you pictures of the structural damage in just 5 years. Its cheap and fairly easy to do, but not worth it if you want to stay safe and/or keep the vehicle out of the scrap yard.
Old September 9th, 2010, 08:58 PM   #22
holshotracer
Its not mine
holshotracer's Avatar
i guess that i'm lucky 35s with no lift
holshotracer is offline   Reply With Quote
Old September 9th, 2010, 10:42 PM   #23
bigblockford79
Big Block Ranger
bigblockford79's Avatar
That Bronco is sharp!!!
Old September 22nd, 2010, 07:47 PM   #24
BUILDIT4X4
BUILDIT4X4's Avatar
I have two full size broncos a 94 and a 95 I am going to be totally straight with you. body lifts are stupid all you gain is more room for tires your frame is in the same spot. I have a 4 inch BDS on my 94 and a six inch 0n my 96 the lift kits are very simple i have had my 94 for awhile and ran it stock for a couple years planning on doing a lift then when i did the lift noticed the stock center bracket was torn. Please listen to this it is worth every penny to do a suspension lift the quality of the brakets are amazing where the stock brackets are just stamped out peices of crap. Please give me a call i would love to go into more detail.
Thanks Ben
616-889-1993
BUILDIT4X4 is offline   Reply With Quote
Old September 23rd, 2010, 11:01 PM   #25
Jrod-13
poser wheeler
Honestly, I wouldn't waste any money on a TTB lift.. its just throwing good money after bad.. A SAS is really no harder than a ttb lift, and cheaper too..
Going rate on a 79' dana 44 is about $100, or less....
Move the factory radius arm brackets back to where the cab mounts are, weld on a track bar mount.. and bolt it in... it's really that easy..
Oh yeah, a set of used 4" 70's coils to clear the crossmember, and a 85-97 F-350 draglink... it all bolts right in..
These trucks drive/handle/wheel so much better with a solid axle its not even funny..
Jrod-13 is offline   Reply With Quote
Page generated in 0.26224 seconds with 38 queries
