d30/d35 ratio id - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2010, 09:23 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default d30/d35 ratio id
93 cherokee 4.0/ AW4 where would i find the axle ratio information? i didn't see any tags on the axles themselves so idk if they are MIA or not.
Old August 9th, 2010, 09:27 AM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Take off a diff cover and look at the ring gear, it is usually stamped on the outside.
Old August 9th, 2010, 10:43 AM   #3
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
most likely 3.55 or 3.73 with towing package on a 4.0/auto
mine with 3.55 pulls 1900rpm at 60, thats with the stock 225/75 -15
assuming your going 60mph
engine rpm / .75 (o/d on 23spline aw4) / (63360 / (tire od * pie)) = gear ratio
Old August 9th, 2010, 08:38 PM   #4
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
call the dealership and give them your vin #
Old August 10th, 2010, 12:05 PM   #5
PavementPounder
PavementPounder's Avatar
Dana only has one listing on their site for an XJ D35 in 1993, so it should be 3.55 if you are correct in what they came from. The only difference is whether it was a LSD.
Get the BOM off either axle tube and stick it in here to be sure:
http://www2.dana.com/expertforms/deabill.aspx
Old August 10th, 2010, 05:55 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
ok. didn't wanna pull the cover just for an id. has fresh fluid front and rear no sense draining it. i'll go with the 3.55 that sounds good for 31's. it doesn't run still so idk the rpm at 60. going to be strictly cheap beater trail rig so idc if it goes faster then 40.
Page generated in 0.19862 seconds with 41 queries
