best way to lift fron strait axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2010, 12:58 AM   #1
85F250460
gettin shit done
85F250460's Avatar
Default best way to lift fron strait axles
i recently bought a 1985 f250 4x4 for a project truck and am looking for a cheap way to lift it. i wanna put blocks in the back, but need a cheap and reasonably easy way to lift the front. i heard blocks were a bad way to lift the front. im looking for about 4-6 inches of lift.... any ideas?
85F250460 is offline   Reply With Quote
Old August 7th, 2010, 06:02 AM   #2
curbdog17
Mini Van
curbdog17's Avatar
FYI 4-6 inch blocks is a bad Idea for the back too.
Just go buy a lift kit.
Old August 7th, 2010, 12:36 PM   #3
85F250460
gettin shit done
85F250460's Avatar
dont wanna spend $800 on a lift kit
Old August 7th, 2010, 12:42 PM   #4
xjmichigan
xjmichigan's Avatar
what do you want to spend?
Old August 7th, 2010, 02:18 PM   #5
Suta99
Suta99's Avatar
If you don't want to spend any money i suggest wood blocks. If you don't want to die spent $800 or leave it how it is.
Old August 7th, 2010, 02:25 PM   #6
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Front springs rear blocks are fine in a 4-6" lift, if you by a lift it will have rear blocks anyways BUT will have a rear lift spring option. Rear blocks do make it axle wrap more but for a beater its fine or put traction bars if it get to bad from old weak rear springs
scramblerman72 is offline   Reply With Quote
Old August 9th, 2010, 05:04 PM   #7
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
I would do shackle flip in back, that will get you around 4 inches in back, then spend the money and just get good lift springs up front. another way to go is add a leafs in back, leveling springs up front and 3 inch body lift. body lift will be your cheapest option.
big_ol_bronco78 is offline   Reply With Quote
Old September 5th, 2010, 05:35 AM   #8
olewhite
olewhite's Avatar
shackel flip with longer shackels in back and add a leaf for front... or just a set of lift leafs for front...
olewhite is offline   Reply With Quote
Old September 5th, 2010, 05:36 AM   #9
olewhite
olewhite's Avatar
i found a 4inch lift for my dodge straight axle for 370 came out to be right over 420 after shipping
Old September 5th, 2010, 05:36 AM   #10
olewhite
olewhite's Avatar
that included shocks... from rough country
Old September 5th, 2010, 11:01 PM   #11
Yota Bill
take a sawzall to the wheel openings...install larger tires.
Old September 5th, 2010, 11:16 PM   #12
kkodet
kkodet's Avatar
x2
and x3 on the shackle flip. You can do it yourself with the factory parts and a welder or some more bolts.
IMO 4 inch blocks is not the best idea. I had 4 inch blocks in my old F-150, which only saw street duty, with no issue, but when I ran only 3 inch blocks in the back of my old jimmy wheeling rig, I had axle wrap like crazy until I pulled them out.
Old September 6th, 2010, 09:11 AM   #13
knaffie
knaffie's Avatar
Buy some all-thread rod and stack up hockey pucks between the body and the frame.
Old September 6th, 2010, 10:34 PM   #14
Yota Bill
I seriously hope this was meant as a stupid joke.
Page generated in 0.30749 seconds with 65 queries
