NAPA's 85-up HP60 4-prong axle nut sockets suck ass - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2006, 11:01 AM   #1
PavementPounder
PavementPounder's Avatar
Default NAPA's 85-up HP60 4-prong axle nut sockets suck ass
Don't buy them - they are very poorly manufactured and way too expensive. Mine wouldn't fit either side. Luckily, one of the nuts was loose enough to spin out by hand. Upon presenting the tool back to NAPA with the nut, the NAPA employee took it in the back to "fix" it. A few moments later I got a refund.
Auto Value stocks them from a different manufacturer with an "external" fit, where the nut is completely surrounded by the socket. My nut dropped right into it and it was at least $20 cheaper.
Old August 14th, 2006, 11:15 AM   #2
bigblue2230
still goin
bigblue2230's Avatar
I have one that is just the external 4 posts sticking out from the end, and it has worked fine, and seems to be pretty solid. I have used the type that you bought though, that surrounds the entire nut, and they are much better to work with. I would definately recomend using those instead.
bigblue2230 is offline   Reply With Quote
Old August 14th, 2006, 12:15 PM   #3
busyfixin
Balls Deep
busyfixin's Avatar
i find the surround type hard to get lined up on the nut, so i prefer the regular unsurrounded one when i can find it. the surround style is stronger though
Old August 14th, 2006, 12:45 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I have an OTC brand one that uses a centering dowel that keeps the tabs lined up. it cost about $55
Yetti
Old August 14th, 2006, 09:08 PM   #5
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
How do you know I didn't use the jedi mind trick on it
or mybee i just have super retard strength
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old August 14th, 2006, 11:07 PM   #6
PavementPounder
Yep, that's what I thought. I knew one of those mushrooms was missing when I went to throw them away...
Page generated in 0.19010 seconds with 41 queries
