83 cherokee fsj update's - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2010, 08:14 PM   #41
sanman
sanman's Avatar
Few more pic's with everything back on it, so now it's time to start on the inside.
sanman is offline   Reply With Quote
Old October 22nd, 2010, 08:17 PM   #42
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Dude! that thing is turning out awesome!!! I'll have to check that thing out next summer when we spend a weekend in Hastings with the inlaws.
Old October 22nd, 2010, 08:21 PM   #43
sanman
sanman's Avatar
Thank's hell if your ever in the area stop over, should be at the dune's next weekend hopefully. Picked up a 401 and have a turbo in the work's so by next summer i hope it will be ready to rock.
Old October 28th, 2010, 06:29 AM   #44
danimal
IS IT JEEPIN TIME
danimal's Avatar
nice build ...needs a rino grille
danimal is offline   Reply With Quote
Old October 28th, 2010, 07:30 AM   #45
bigdogwaggy
bigdogwaggy's Avatar
lookin good.. i guess i need to get my but in gear.. cant let you be the only good lookin waggy on here.
bigdogwaggy is offline   Reply With Quote
Old October 28th, 2010, 11:13 AM   #46
sanman
sanman's Avatar
Thanks guy's and yes it does need a rhino grill.
Old February 18th, 2011, 06:03 PM   #47
sanman
sanman's Avatar
Well i have been doing a little work got the headliner done and the gauge's in but nothing to take pic's of. Did get the 401 done skipped the turbo and just went with the little blue bottle will post pic's when i get it home made 553hp off the bottle have not dynoed it on the bottle yet. Need to get some more part's before i install it should be done in a couple of month's if the money allow's.
Old February 19th, 2011, 08:22 PM   #48
sanman
sanman's Avatar
Got these for it also
Old February 20th, 2011, 07:35 AM   #49
MidMichFSJ
MidMichFSJ's Avatar
I would like more details on this 550+ hp 401. Having built a 401, that is a BIG number. I would like to know how you did that and mine only makes 400 on pump gas. Post the dyno sheet on so I can see the numbers please.
MidMichFSJ is offline   Reply With Quote
Old February 20th, 2011, 08:12 AM   #50
sanman
sanman's Avatar
I have a friend's dad who has been racing amc's for year's and know's them well i'll get all the info when i go pick it up. I have been helping him on it to trying to soak up some knowledge on amc motor's as i am not real familiar with them. This is some of what i know with out the paper work.
# 1 take's more $ then i thought
Indy head's ported polished
Indy intake
Eagle rod's
Steel crank
Wiseco piston's 11-1
Msd
Holley 930
Comp cam 252/258 630/630 i think
Ati damper
This is of the top of my head now all i need is $ to finish paying for it.
Old February 20th, 2011, 08:21 AM   #51
sanman
sanman's Avatar
How does your 401 do in your's, i figured it would take alot of power to make this feel strong and pull hard for the size of them. I know of a guy who run's his fsj on the track and i think he run's in 12's or high 11's i'll see if i can find more info on his also.
Old February 20th, 2011, 04:15 PM   #52
J Truck Rick
J Truck Rick's Avatar
This is NOT a waggy...this is a CHEROKEE! NOT a chief either!...This is a NARROW TRACK CHEROKEE........I have one just like it,as well as a wide track cherokee 'S' I had a cheif,a laredo,and a 4-door 'S' '83 was the last year AMC built the full-size cherokee,they were built from'74-'83.
J Truck Rick is offline   Reply With Quote
Old February 23rd, 2011, 11:59 AM   #53
ghinmi
What do you want to know about it?
ghinmi is offline   Reply With Quote
Old February 23rd, 2011, 05:40 PM   #54
sanman
sanman's Avatar
Do you own the black wagoneer?
Old February 23rd, 2011, 05:42 PM   #55
ghinmi
Yes
Old February 23rd, 2011, 05:46 PM   #56
sanman
sanman's Avatar
LOL i thought i had saw some info on your's some where but don't remember where, was wondering about your 401 and what you had done to it.
Old February 23rd, 2011, 06:18 PM   #57
ghinmi
Stock 1977 heads with stock bridged rockers
Stock rods with ARP bolts
9.5:1 KB pistons (junk)
224 duration .450 lift cam
Edelbrock dual plane air gap intake
Edelbrock shorty headers
Basically nothing special, probably a 400 hp engine. It went a best of 13.24 @ 99 mph on motor. On the bottle it ran 12.5x @ 105 when the clocks were on, faster when it wasn't if you know what I mean. Truck was built for drag but looked and sounded stock, 2wd dana 44 front, 2wd th400 w/10" converter, 4.10 gears, 28x11 tires. I semi-retired that truck from racing and it's got a stock 360 now. I'm going to build another 401 for it this summer. Nothing special just enough to run mid-high 12s on motor.
I've been redoing the first 401 for my new Jeep. Pretty much a twin to yours except iron heads with a lot of work. And injected on E85. Hoping for somewhere in the neighborhood of 530-540 hp. Going in an 83 Cherokee WT.
Old February 23rd, 2011, 06:41 PM   #58
sanman
sanman's Avatar
What casting # are your head's, your stuff look's very nice and good luck with your new motor. The guy helping me had a line on an indy block but way more $ then i was going to spend. I hope to have mine going in a few month's as long as the money is there.
Old February 23rd, 2011, 08:35 PM   #59
ghinmi
Heads are 502-2 casting. They're the first set of heads I've done by myself so we'll see how they actually work. The flow numbers are good but we race Jeeps not flow benches. I did 2.08/1.74 valves, full port job, reworked combustion chambers (now 64cc), etc. These heads are just temporary until I can get a set of Indys. I'll be able to use them for the new 401 in the black Jeep so it's not like I wasted my time on working a set of iron heads.
I know what you mean about the $$ thing. My chassis guy had an opening so I sent it off for the cage last week and had to put $$ down, then my engine parts bill came the next day. Double ouch.
I think you talked to my old man this summer at a car show. I know he showed me pictures of your Cherokee. Looks like you have done a lot of nice work to it since then. Any pictures of the engine?
Old February 23rd, 2011, 08:43 PM   #60
fruzz
we todd did
fruzz's Avatar
ya ditch it
fruzz is offline   Reply With Quote
Page generated in 0.46158 seconds with 84 queries
