Wanted 4.0 L AMC 242 i6 and ax-15 trans. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2010, 10:09 PM   #1
jeepjeep94
Default Wanted 4.0 L AMC 242 i6 and ax-15 trans.
i currently own a 94' wrangler, i'm running the stock, 2.5l AMC I4, and an ax-5 tranny. i'm looking to upgrade to preferably a 4.0l AMC I6, or something comparable. In addition to that i'm looking for an ax-15 transmission and the same goes for that in the sense that i would accept something comparable. mileage isn't too much of an issue, and I wouldn't like to have to put any extra money into the engine or transmission.
thanks.
jeepjeep94 is offline   Reply With Quote
Old August 3rd, 2010, 10:35 PM   #2
jeepjeep94
bump
Old August 3rd, 2010, 10:46 PM   #3
jeepjeep94
bump
Old August 4th, 2010, 12:09 AM   #4
Strangler
Strangler's Avatar
I have a brand new, never started 2004 4.0 $1500
Old August 4th, 2010, 10:48 AM   #5
mtheaded
i have a complete engine-swap package for you. 4.0 from a '97 TJ. runs great. i also have the complete intake, sensors, wiring, and computer for a '94 YJ. this would make it a drop-in motor (except the mounts on the frame) for your Jeep. the wiring, sensors, etc., everything you need, including flywheel and clutch. PM me if interested or for more information....
mtheaded is offline   Reply With Quote
Old August 5th, 2010, 09:37 PM   #6
jeepjeep94
bump
Old August 6th, 2010, 01:11 AM   #7
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
pretty sure you're going to need a t case because i think the 4cylinders used 21 splines
coolgareray is offline   Reply With Quote
Old August 6th, 2010, 02:11 PM   #8
orionn
orionn's Avatar
Correct.
You will need a 23 spline input NP231 t-case, or a planetary set with 23 spline input to install into your t-case. I have both if your interested.
I also have an AX15 trans, shifts well, but other than that I have no info on it.
I also have a Down East Offroad Dana300 flip kit to put a Dana 300 t-case behind an ax15 (or any other Jeep 23 spline output trans) to make it a Drivers drop t-case.
I probably have other stuff as well.
orionn is offline   Reply With Quote
Old August 6th, 2010, 02:44 PM   #9
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
I got a 4.0 out of a 95 xj that runs awsome. You pull it $150, if I pull it it'll be $225. call me at 517-317-3704 if your interested. I also have the aw4 behind it that I'll throw in for 100.
lastmanstandin is offline   Reply With Quote
Tags
amc, ax-15, engine, i6, transmission
Page generated in 0.20849 seconds with 50 queries
