D44 D30 TJ 4.88 Detroits Warn 5.5 Alloys Dutchman 37s Allieds - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2010, 06:43 PM   #1
Rubilooe
Rubilooe's Avatar
Default D44 D30 TJ 4.88 Detroits Warn 5.5 Alloys Dutchman 37s Allieds
Going with d60 and d70 so these need to go .
Front is a factory D30 set up for 3 link and trussed ,Rockcrusher cover with lube locker,Detriot EZ Locker ,4.88 Yukon Gears,Alloy inner axles,Warn 5 on 5.5 Lockout hub conversion ,Allied axle tube seals,Currie HD Steering,All bearings, axle joints and seals are freshly installed .
Rear is a Dutchman Motorsport built D44 with a triagulated setup ,4.88 Yukon gears,Detriot Locker,rockcrusher cover with Lube Locker,freh bearings and seals,
All the brakes and lines were recently replaced .
maybe 1000 miles since allwas gone thru .
I have wheeled these with 35s and 37s with no problems at all both axles lock with no problems. 1900.00 for all . will trade for 39" tires 8 lug Beadlocks 6.5 16 or 17 inch Thanks 574-238-2941
KDN KUSTOMS
Rubilooe is offline   Reply With Quote
Old August 3rd, 2010, 06:48 PM   #2
Rubilooe
Rubilooe's Avatar
Default More
4 37x12.50x15 IROK radials mounted om Allied Competion Beadlocks 32 bolt 5 on 5.5 bolt
used on a trail rig so some scars are there nothing bad . 90% or better tread and the outer rings on the beadlocks have a few scars no bends.
1400.00 all four
Buy with the axles and 1200.00 will buy them.
Thanks
KDN KUSTOMS
Old August 4th, 2010, 12:15 AM   #3
bono
bono's Avatar
will you separate the rear axle?
pm me if your willing thanks
bono is offline   Reply With Quote
Old August 4th, 2010, 08:25 AM   #4
Rubilooe
Rubilooe's Avatar
Default Seperate
I will sell as a pair only Thanks
KDN KUSTOMS
Page generated in 0.17172 seconds with 35 queries
