bending Alum. tubing?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 2nd, 2010, 03:17 PM   #1
trailrail302
Im going FAST!!!
trailrail302's Avatar
Default bending Alum. tubing??
I have bent alot of DOM but I have to bend some 1 1/2 120 wall alum tubing. Anyone done this before? Not sure how the alum will react. will it crack the tubing if I just stick it in the bender and let her rip or should I pre heat the material before I bend it ? I would think it would be fine but I want to research a little bit before a burn through this material..
Thanks,
trailrail302 is offline   Reply With Quote
Old August 2nd, 2010, 03:40 PM   #2
95geo
newbie
95geo's Avatar
In my experiences, heating any material while using a bender and die never goes well. It gouges a LOT easier and deforms more.
Old August 2nd, 2010, 10:15 PM   #3
jaysusr
jaysusr's Avatar
alum will give you very little warning of when its TOO hot. Then boom its junk.
Old August 3rd, 2010, 08:50 AM   #4
trailrail302
Im going FAST!!!
thanks guys, I think it is best to just bend it like normal...
Old August 3rd, 2010, 09:42 AM   #5
chevotass
chevotass's Avatar
ask on a boat forum
Old August 3rd, 2010, 09:47 AM   #6
Bones
Bones's Avatar
this isn't done yet?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 3rd, 2010, 12:07 PM   #7
trailrail302
Im going FAST!!!
Ya your one to talk. By the way both you and chevota need to supply your own gear. So start buying tackle...... I cant offored to charter your two asses for musky.
Old September 8th, 2010, 11:25 AM   #8
Bones
Bones's Avatar
x2
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old July 21st, 2011, 01:59 PM   #9
ricthewrench
i make everything
learned a sweet trick from a grizzly weldroid! acetylene soot on the bend area. heat it up, when the soot changes color, pull your bend. watched it done, was very impressed. 1" solid stock was the mat'l he bent. check it out!
ricthewrench is offline   Reply With Quote
Old July 21st, 2011, 02:38 PM   #10
Tab
Tab's Avatar
its called Aneiling. I'm sure I spelled it wrong though. It makes the aluminum soft though so I hope it wasn't a roll cage he was building.
Old July 21st, 2011, 03:02 PM   #11
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Is there any easy way to undo the aneiling? I have done it with the acetylene before but have never had to worry about the strength of the aluminum afterwards. I'm guessing you could have it professionally heat treated but I am looking for a backyard way of doing it.
Old July 21st, 2011, 03:13 PM   #12
Tab
Tab's Avatar
Not sure, I've never done it. You see real fabricators like Jesse James do it when they are hand forming tanks and such. I'm sure it would need to be brought back, probably just heat treating. Jim would know.
Old July 21st, 2011, 08:06 PM   #13
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Seems like if you get the right grade of alum tubing it will bend fine. Just like plate cant bend 6061 without cracking 3003 bends fine.
sbcrichie is offline   Reply With Quote
Old July 22nd, 2011, 01:36 PM   #14
danimal
IS IT JEEPIN TIME
danimal's Avatar
I am curious how you made out I have been think of trying the same thing.
I have been told they make these crayons that turn chalky at a certain temp so you know when you've reached the correct temp for annealing, these work better then the soot method for 6061 or other hardened alloys. I think just shy of 800 degrees is recomended.
I would cold water quench anything used as "structural" to bring it back to temper. I am pretty sure aluminum will work its way back to hardness over time on its own but cold water quenching would speed that process up. at least I know 3003 will or can be annealed several times without affecting the hardness after it has cooled, not sure on the hardened alloys but I believe that still holds true
danimal is offline   Reply With Quote
Old July 22nd, 2011, 01:45 PM   #15
trailrail302
Im going FAST!!!
here is a link to the finished project.
http://www.greatlakes4x4.com/showthr...light=trolling
It worked out pretty good I wish I would have just bought non hardened material in the first place though. And I did not quench it like you say to re-harden it. I anieled it and then bent it after it was cooled. IT bent great after anieled. Before that it would get about 12deg. and snap in half. It definetly does not seem as strong after anieling, however, I think it is strong enough for my application.
Are you looking to do this for a trolling tower as well?
If I was to do it over I might really consider spending the extra cash and doing stainless steal.
Old July 22nd, 2011, 01:51 PM   #16
trailrail302
Im going FAST!!!
X2 I had 6061 not knowing and allready invested in the material so I had to aniel it to bend. I agree proper material makes all the difierence. I had no idea of waht to get at the time but like anything you learn from experience and I now know not to get 6061 for bending...lol and I learned how to aniel so that is pretty cool...
I would like to learn a way to get the strength back into it.
Old July 22nd, 2011, 01:53 PM   #17
trailrail302
Im going FAST!!!
This is waht we did but we heated it up until the soot burned completely off.
Page generated in 0.36698 seconds with 74 queries
