Tire inflator / Deflator - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2010, 07:45 PM   #1
Hugeamerican
Upgraded to ROOKIE
Hugeamerican's Avatar
Default Tire inflator / Deflator
Seen this on another site, Ordered parts from McMaster Carr put it together today
It takes forever to fill tires back up one at a time, sit there and hold the trigger for each tire
Plug all 4 quick connects to tires, open petcock valve to air down, close valve to see tire pressure.
When filling tires back up same procedure plug it in turn the compressor on and I can pack jeep put top up ETC.
Not chained to each tire then pack the jeep. tried it today worked great
At the BBQ run sister in law came to the dunes and it took over a half hour to fill both jeeps up
This will be a lot better, just monitor the pressure once in awhile
Still carry old hose for single air up if needed
Hugeamerican is offline   Reply With Quote
Old July 31st, 2010, 04:03 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
My dad made one of these for his YJ. He calls it the "Spider".
Old August 13th, 2010, 04:24 PM   #3
Bishop
Bishop's Avatar
have you tried this yet?
If you have not, I would think that the slow fill ups are from the pump that you are using. Most of those small pumps don't produce the flow needed for fast fill ups, with out a reserve tank.
just some food for thought.
Old August 24th, 2010, 09:07 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
Ive been wanting to build one of these for years.. just never got around to it... good to see im not the only one..
Old September 18th, 2010, 01:19 PM   #5
Speedy2222
what did you wind up paying for that warn pump if you don't mind me asking
Speedy2222 is offline   Reply With Quote
Page generated in 0.24638 seconds with 38 queries
