how am this pattern look? **UPDATE** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2010, 09:12 PM   #1
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Default how am this pattern look? **UPDATE**
Have about 1000 miles on the axle - this pattern provides quiet cruising with a bit of noise coasting. Nothing I can't ignore.
@clarkstoncracker
Old July 27th, 2010, 09:18 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
thats not to bad
H.o.r.e
Old July 27th, 2010, 09:19 PM   #3
JeepMizer
Looks yellow to me.
JeepMizer is offline   Reply With Quote
Old July 27th, 2010, 09:22 PM   #4
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Nice TrueTrac :jealous:
1988JeepXj is offline   Reply With Quote
Old July 28th, 2010, 04:30 AM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by JeepMizer View Post
Looks yellow to me.
I don't know you Sir, but I think I like you.
Then you're going to be pissed to know this is going in an Astrovan...
@clarkstoncracker
Old July 28th, 2010, 06:13 AM   #6
crassell
crassell's Avatar
post pic of astrovan
crassell is offline   Reply With Quote
Old July 28th, 2010, 06:30 AM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
@clarkstoncracker
Old July 28th, 2010, 08:55 AM   #8
creeping death
I'm that guy.
creeping death's Avatar
pimpin!
Old July 28th, 2010, 08:56 AM   #9
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I'd run it....
Old July 28th, 2010, 10:38 AM   #10
crassell
crassell's Avatar
nice looking van
you should change your name to SocKeR mOm
Old July 28th, 2010, 11:15 AM   #11
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Looks like good tooth contact to me.
Old July 28th, 2010, 11:21 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
nice looking van
you should change your name to ScOcKeR mOm
You should change your name to shut the hell up!
@clarkstoncracker
Old July 28th, 2010, 12:47 PM   #13
95geo
newbie
95geo's Avatar
It looks like it's a little out on the tooth, depending on how much of a PITA it was to get to that point, I'd see if you can get the contact patch into the root a little further and slightly outwards on the diameter. It's a little hard to tell in the pics but does the contact patch fall off the tip of the ring gear teeth or is it just some of the scuffing after the contact area?
I usually mess with it until I get the sweet spot that looks good and then see if I can get it any better making .002-.003" adjustments, if each change makes it worse then it's a good sign you're in the sweet spot.
But, if you dont have setup bearings and it's a big PITA then I'd say it's close enough and just run it if all the clearances and preloads check out. For what it's duty cycle is, I'm sure it'll be issue free.
Old July 28th, 2010, 12:56 PM   #14
joe_jeep
welfare wheeler
joe_jeep's Avatar
id wheel it.
Old July 28th, 2010, 01:00 PM   #15
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Shallow. Add .003 to .005.
The higher on the tooth the weaker the gear set, I would not run that pattern.
JcrOffroad
Zoom Zoom!
Old July 28th, 2010, 01:19 PM   #16
Tom
Because racecar
Tom's Avatar
Scooter,
I'm assuming you just did a carrier swap... Correct? If so, how much backlash do you have?
I agree with this
If he did just a carrier swap, in theory he shouldn't have to change the pinion depth. I would recheck backlash first before sinking it. If the backlash is on the high end, he could tighten it up and recheck the pattern, it would probably bring it to a near perfect pattern.
I also agree with Bryce... It's an Astro Van, it would probably be just fine. It isn't really going to see hard use.
I would try adjusting first by sinking it or adjusting BL before I ran that pattern.
Old July 28th, 2010, 01:35 PM   #17
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
He said pinion bearings as well, but even if not, I've seen factory setups that weren't great patterns.
Backlash will move the pattern slightly deeper or shallow, but it tends to move the pattern more from heel to toe than anything.
It takes what, 20 more minutes to make it perfect?
JcrOffroad
Zoom Zoom!
Old July 28th, 2010, 01:48 PM   #18
Tom
Because racecar
Tom's Avatar
I agree with as well...
If he pulled the pinion, then I agree try and sink it. I have also crappy patterns on factory GM gears.
Did you see my disclaimer on the bottom of my last post?
Old July 28th, 2010, 01:57 PM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I did see it.
JcrOffroad
Zoom Zoom!
Old July 28th, 2010, 04:14 PM   #20
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
IF I had setup bearings for my pinion, or a press - yes.
I have no press to get that damned bearing off to add teh sheemz. Currently has an 0.041 in there.
Consarn it all!
@clarkstoncracker
Page generated in 0.64288 seconds with 83 queries
