Mira's Jeep Cherokee Sport - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2011, 07:53 PM   #141
Spudy
Redneck Excavator
Spudy's Avatar
hey craig if u need some welding done you know where i live :-)
Spudy is offline   Reply With Quote
Old August 14th, 2011, 08:00 PM   #142
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by 1x1_Speed_Craig View Post
Guess what showed up on the door step today? All of this Eastwood product, compliments of Matt at Eastwood. Thanks for the sponsorship, Matt. Mira & I both appreciate it greatly!
Craig
Outstanding!!!
@clarkstoncracker
Old September 3rd, 2011, 08:24 PM   #143
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Mira & I would like to thank BJ at RockSolid Performance here in Cedar Springs, Michigan for the project sponsorship via custom machine work on Mira's rear Dana 44 truss. Much appreciated, BJ! The issue was due to the slight difference of placement of the axle vent fitting on an XJ vs. an LJ. The truss is an XJ truss, while the donor Dana 44 axle was pulled from my 2005 LJ.
Craig
Original hole (shown on the opposite side):
Newly-machined hole:
ID:	83071   Click image for larger version
Old September 3rd, 2011, 08:38 PM   #144
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
It's great to see all of these companies chipping in! The build is looking good.
Old September 4th, 2011, 08:38 AM   #145
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'm just throwing this out there, but school's coming up quick (or has it already started?) - but I kinda expected a big push during the last few days of summer...
@clarkstoncracker
Old September 4th, 2011, 07:18 PM   #146
1x1_Speed_Craig
Simplify...
We're very thankful for both the company and individual sponsorship support.
I know, I know. With young kids, there's always something going on, and the Jeep is just one of them. We did work some today on getting the Dana 30 pulled from my '05 LJ, which will be painted and installed as-is (with the exception of getting some LCA skids welded on) in Mira's XJ. Here are a few pics from today's work.
Craig
Here's Mira working on the front D30 shock removal.
A dusty hood is irresistible for an 11-year-old kid.
Mira strikin' a pose in my LJ.
And a close-up. She has a potential for a promising future career in used car sales.
ID:	83085   Click image for larger version
ID:	83086   Click image for larger version
ID:	83087   Click image for larger version
Old September 11th, 2011, 06:36 PM   #147
1x1_Speed_Craig
Simplify...
We ordered, and just received our H.D. Offroad Engineering XJ Shackle Relocation Kit a couple days ago. I stumbled across this set-up over on NAXJA. Because we need a little additional height in the rear (the front will have 2" BB spacers, and this kit adds ~1-1.5"), and to get a better shackle angle and better articulation, I ordered up the kit from Brian over at H.D. Offroad Engineering. There are some offerings from other companies, but this looked the most stout and heavy-duty to me.
Here's what the pre-installed set-up looks like:
Just because I'm a perfectionist , I rounded off all the corners with a grinder & sander, and prepped the shackle relocation kit and the T&T Dana 44 truss for paint. I primed all but the bottom 1/2" of the truss, which will get 3M Weld-Thru primer. I wanted the inside of the truss to be well-protected from the elements.
After the first coat of Eastwood primer...
ID:	83319   Click image for larger version
ID:	83320   Click image for larger version
Old September 11th, 2011, 06:51 PM   #148
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
Looks good
SizeMatters is offline   Reply With Quote
Old September 11th, 2011, 07:00 PM   #149
curbdog17
Mini Van
curbdog17's Avatar
Craig, I wish I was your Daughter. Im jealous.
Nice Jeep Mira, you and your dad do great work.
Old September 11th, 2011, 10:02 PM   #150
Spudy
Redneck Excavator
Spudy's Avatar
looking great
Old September 11th, 2011, 10:10 PM   #151
adamzr2
numero douce undela
adamzr2's Avatar
drooooollll
adamzr2 is offline   Reply With Quote
Old September 13th, 2011, 07:12 PM   #152
motox168
Bare Bones Offroad
motox168's Avatar
Craig do you plan on also running a longer shackle I had a friend who ran a shackle relocation believe it was hd and couldnt use stock shackls bc they bottomed out on the bracke he need to use a lift shackle to get the wider end of the shackle further away from the bracket on compression
motox168 is offline   Reply With Quote
Old September 13th, 2011, 07:57 PM   #153
1x1_Speed_Craig
Simplify...
My assumption is that you can use a stock, or aftermarket, shackle set-up based on the install photos posted on NAXJA by the guy who builds these (see photo below). I'll have to see where things fall height-wise in the rear before deciding for sure, but I suspect we'll use an aftermarket shackle with a slight amount of lift.
Craig
Old September 13th, 2011, 08:25 PM   #154
1x1_Speed_Craig
Simplify...
Originally Posted by Spudy View Post
looking great
Originally Posted by adamzr2 View Post
drooooollll
Thanks guys!
Old September 13th, 2011, 08:50 PM   #155
littletrucker
I'd hit that
littletrucker's Avatar
I concur looks like it'll come out awesome
Old September 20th, 2011, 07:16 PM   #156
1x1_Speed_Craig
Simplify...
The HD Offroad Engineering install continues...
Mira is a little apprehensive about using the MAPP Gas torch...can you tell? She's heating the upper shackle bolt to help free it up for removal.
Because I'm a nice dad, and because Mira would have gotten completely bent trying to break the bolt free , I loosened (slightly) the upper shackle bolt, and then turned Mira loose with the 1/2" ratchet.
I mentioned previously that this Jeep build would be full of teaching moments. This is one of them. Teaching moment = Rusty Jeep bolts are a PITB (pain in the butt). Even after I broke it free, and after Mira added heat, the bolt was still somewhat tough to remove. Note the look on Mira's face. After spouting off a few comments in a seriously annoyed tone, I explained to Mira that this WAS a teaching moment, and this is one of the things that us "Jeep folk" deal with on a regular basis. I then became "Mr. Nice Guy" again and removed the bolt the rest of the way for her.
Shackle removed from the mount.
ID:	83701   Click image for larger version
ID:	83702   Click image for larger version
ID:	83703   Click image for larger version
Old September 20th, 2011, 07:23 PM   #157
1x1_Speed_Craig
Simplify...
Here's the upper portion of the HD Offroad Engineering kit in place. It's a tight fit. NOTE: Any high-dollar paint you use on this upper insert portion will be scraped up/off when pressing it in place. Tolerances are tight...nice fit.
Here's the actual multi-position shackle mount bolted in place.
Mira reinstalling the original upper shackle bolt, which now holds the shackle relocation kit in place.
The install is still in-progress, as Mira had to get ready for bed (school night). Also, the stock shackle is a tight fit in the multi-position mount. I'll work on getting it finished up later this week.
Craig
ID:	83708   Click image for larger version
ID:	83709   Click image for larger version
Old September 20th, 2011, 07:34 PM   #158
jbsjunk
Little Member
jbsjunk's Avatar
That's a look we all know.
You didn't have a cheater bar for her to lean on? I usually need my 3 foot bar along with my 2 foot ratchet to get those out.
Old September 20th, 2011, 08:52 PM   #159
1x1_Speed_Craig
Simplify...
You know it, Jeff! We didn't have enough clearance underneath for any real length of cheater bar, but I did explain the concept to her with a shorter piece of pipe. She'll have plenty of other opportunities to use one (for example, on the passenger-size install ).
Craig
Old September 20th, 2011, 09:38 PM   #160
branch92
Only in a jeep
branch92's Avatar
Craig
i would like to see after all of it is installed thinking about running these but i think i will have to go back to a stock shackle to maintain ride height
branch92 is offline   Reply With Quote
Page generated in 0.40080 seconds with 84 queries
