Mira's Jeep Cherokee Sport - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2010, 09:39 PM   #61
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
What are you going to coat the new floor with?
When I do mine in a couple weeks I think I'm going to paint the inside and out with high gloss Chassis Saver so dirt falls/washes off real easy, and I'll have a nice rust barrier. Also that way any of the existing floor that only has surface rust will be taken care of as well. I'm also probably going to line the the inside of the floor with some sort of sound dampener after the Chassis Saver, before I put the carpet back in, but I haven't made up my mind what type yet.
1988JeepXj is offline   Reply With Quote
Old December 9th, 2010, 06:56 AM   #62
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
I plan on using Eastwood paint inside & underneath (I'm just saving to make the order). The underside will then be top-coated with 3-M Rubberized Undercoat, which I already have, and have used in the past (great stuff). I'm not sure if the interior will get a rubber mat, or some sort of bedliner when we're done. I prefer not to use carpet.
I have used POR-15 products quite a bit in the past, and it's durable stuff. However, it's very finicky to apply, and I don't take short cuts in the prep work. It's annoying enough that, after several projects/applications, I don't care to use it much anymore.
Craig
Old December 10th, 2010, 10:14 PM   #63
bigbchevy
missmrgreenagain
bigbchevy's Avatar
looking good very cool project!
H.o.r.e
Old December 10th, 2010, 10:16 PM   #64
curbdog17
Mini Van
curbdog17's Avatar
Great Progress
I like the inspiration for your paint too.
Old December 10th, 2010, 10:31 PM   #65
Looks like your gonna have a real nice upgrade from your last jeep .........
Looks really good Mira
Old December 10th, 2010, 10:38 PM   #66
1x1_Speed_Craig
Simplify...
Originally Posted by curbdog17 View Post
Great Progress
Originally Posted by Raerad View Post
Cool....Rock on Craig, Your daughter is gonna be styling......love your'e update's and I'm sorry I'm a newbe...I'll work on that.....
Thanks, gentlemen.
The Chiefblahblah problem has been somewhat solved - he's been added to both Mira's and my "Ignore" list. At least she won't see his garbage. It's truly sad that I'm trying to rationalize with an adult about being appropriate in a proud 5th-grader's build thread.
Back to what matters...the build.
We won't have time to work on it this weekend, as we'll be downstate celebrating Christmas with my family. The floorpans will be the primary focus over the next month, but we may take a break to get her welding her little Ballistic Fabrication skull on her D44 differential cover. She's itchy to get welding.
Craig
Old December 10th, 2010, 10:39 PM   #67
1x1_Speed_Craig
Simplify...
Still being used? Excellent! Mira will love to see the photo. Thanks for posting it.
Craig
Old December 10th, 2010, 11:53 PM   #68
prozak1986
prozak1986's Avatar
awsome job on the jeep craig and mira , keep up the good work , i have a few years before my kids are old enuff to do a build like this ,., dont let the bad posts stop you from building the jeep mira your doing a good job
prozak1986 is offline   Reply With Quote
Old December 12th, 2010, 02:27 PM   #69
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Craig
Are you using anything between the undercoat and the metal? I was going to undercoat my 99 and aside from getting rid of some surface rust I was wondering if I needed to paint the surface or if the undercoat would provide enough protection.
ckupq is offline   Reply With Quote
Old December 12th, 2010, 07:16 PM   #70
1x1_Speed_Craig
Simplify...
We'll be painting it first, then undercoating. I definitely wouldn't just apply the undercoat over bare metal (just my $0.02).
Craig
Old December 12th, 2010, 07:43 PM   #71
curbdog17
Mini Van
curbdog17's Avatar
So how many years before Mira gets a license?
Are you going to let her wheel it before then?
Old December 12th, 2010, 07:49 PM   #72
1x1_Speed_Craig
Simplify...
She's 10 now, so she obviously has a while. I'm guessing it'll be done in 2-3 years...drivable before then, most likely.
We have 10 acres here - 5 acres lawn & 5 overgrowth/field out back. I'd like to develop some sort of mini course/play area out back down the road. She already drives my XJ around the back of the property (propped up on a couple hardcover books with the seat all the way up). She does great with it.
Craig
Old December 13th, 2010, 09:48 PM   #73
Shotgun
I only wheel with boats.
Shotgun's Avatar
This looks sweet Craig, I'll have to stop by next time I'm in Cedar to check it out.
Old December 14th, 2010, 01:35 PM   #74
skife
skife's Avatar
Craig
if you need some help building a mini course in your backyard, i could give you a hand.
Old December 15th, 2010, 05:14 PM   #75
thatjeepguy
Weekend Warrior
thatjeepguy's Avatar
hey craig, and mira
i finally looked at your build thread and can't tell you enough how awesome i think it is, its these kind of things that kids will remember doing for the rest of their life.
keep up the good work guys and keep the pictures coming :D
btw... did you end up selling my old D44 or are you still planning on using it on the Mira project, i know you ordered the ballistic fab cover (which would almost be a dead give-away, but i wasn't sure if you found another D44 or not)?????
thatjeepguy is offline   Reply With Quote
Old December 15th, 2010, 08:56 PM   #76
1x1_Speed_Craig
Simplify...
Thanks Justin.
Originally Posted by thatjeepguy View Post
hey craig, and mira
Thanks Alex. We resold your D44, but kept the HD diff cover (Mira will weld the Ballistic skull to that cover). We bought another D44 from someone here on GL4x4 at the same time, but it was disassembled and 1/2 the price. Since we planned on going through it anyway, we kept the cheaper one.
Craig
Old December 25th, 2010, 05:56 PM   #77
1x1_Speed_Mira
I am the Ninja Fairy...
1x1_Speed_Mira's Avatar
This is my AWESOME bumper I just got for Christmas today...IT ROCKS!!!
I'm SOOOOOOOO excited to paint it!!!
This is me with my AWESOME new battery holder with skulls on it - another part of my Christmas present...
-Mira
ID:	72266   Click image for larger version
1x1_Speed_Mira is offline   Reply With Quote
Old December 25th, 2010, 06:02 PM   #78
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
thats awesome mira, im jelous! i wish i got jeep parts for christmas. your project is looking awesome!
Old December 25th, 2010, 06:17 PM   #79
1x1_Speed_Craig
Simplify...
BTW, do you see the pink bandana she's holding in the first picture? After the rest of the Christmas morning hoopla was done (before we went out to the garage), Mira dug the bandana out of her room, and said she had to be blindfolded before going outside. She wanted the "full effect" when her bumper was unveiled.
The battery box was a bonus gift...got a great Black Friday sale deal.
Mira was excited about both items, and also about how her floor pan repair is coming along.
It was a GREAT Christmas morning, especially the homemade gifts I got from my girls. There's no way you can top those types of gifts!
Craig
Old December 25th, 2010, 08:22 PM   #80
jared
Can't Worry About It
jared's Avatar
This looks like what I want my next Cherokee to look like. Not extreme just a nice daily with looks to kill.
I like the BBQ paint idea, but I'm hoping my tj stays green forever.
jared is offline   Reply With Quote
Page generated in 0.67022 seconds with 84 queries
