O2 Sensor simulator - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 12th, 2006, 03:47 PM   #1
Hombre
I carry a shank
Hombre's Avatar
Default O2 Sensor simulator
I have a '97 Dodge pickup with a 5.9 engine. It has dual exhaust (Flo-Masters). There is no catalytic converter on it. Of course, I get the "Check Engine" light all the time and it's driving me nuts.
Both the upstream and downstream O2 sensor were removed. Will one of the O2 sensor simulator's work and keep the "Check Engine" light from coming on? Also, with a simulator attached will the "Check Engine" light come on if another problem is detected?
With the upstream O2 sensor taken out, will my air/fuel mixture be o.k.? Will the ECM be damaged without having the upstream or downstream O2 sensors? Which O2 sensor simulator should I buy? Thanks for any help.
Hombre is offline   Reply With Quote
Old August 12th, 2006, 07:26 PM   #2
Pre4runner
Bike Dude
Pre4runner's Avatar
Search for this... its been brought up a lot but the upstream O2 is needed for a fueal air... its kind of a backup but you should have it... the simulater will get rid of the rear O2 and the light. The check engine will work fine after that.
Old August 14th, 2006, 11:52 AM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You need both sensores for your engine to operate correctly, however, you can get by with just the front O2 sensors.
You'll pay for them in the first month on fuel savings alone.
@clarkstoncracker
Old August 14th, 2006, 11:56 AM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
No, it is not a backup, it is needed for the feedback control in the ECU. Without it, the ecu just throws fuel in based on a small table. Depending on other modes, this ammount may be rich, or it may be lean.
People that have no clue about automobiles and modify them (the person/s that removed Hombre's O2 sensors for him) should be beaten soundly.
@clarkstoncracker
Old August 25th, 2006, 09:22 PM   #5
user name
keep your stick onthe ice
user name's Avatar
i thought that after cat sensor mostly just to tell you if the cat wasnt working right. and if some misinformed person thought removing a good working cat would gain them 5000 horsepower then you put the sim in and the computer wouldnt know the cat was gone
Page generated in 0.27353 seconds with 38 queries
