2wd at Silver Lake - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > Rules, Regulations, Trail, and ORV Park Chat
Old July 18th, 2010, 12:33 PM   #21
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Only thing I am worried about is my jeeps short arm/radios arm suspension sucks in 2wd reverse (its almost usless backwards)
scramblerman72 is offline   Reply With Quote
Old July 18th, 2010, 12:38 PM   #22
Originally Posted by scramblerman72 View Post
2wd all over the place is the only way to fly unless dragracing... Jim I see you in 2wd all the time also. Corse you have paddles and a V8 and a YJ (best damm front clip ever) lol
Actually Dave, I sold the paddles a year ago. I go everywhere I want in 2wd with my Iroks. Maybe you should follow me up the right side of test hill and the second hill. Those are a workout in 2wd.
Old July 18th, 2010, 12:45 PM   #23
jeepinRRT
jeepinRRT's Avatar
I'll run most of the day in 2wd just for the fun of it. I have a LSD and 33" ATs, so I have sort of a perfect set up for 2wd on a stock motor. LOW PSI will do you well, I have went up test in 2wd on the steepest part that day, but it took a few tries and a decent run.
As mentioned, tow points and a strap and have fun!!
jeepinRRT is offline   Reply With Quote
Old July 18th, 2010, 12:54 PM   #24
Smiley
Smiley's Avatar
Do not run more than 10 psi in the rear tires, someone earlier suggested 15, you would not make it up the entrance ramp. When you have enough low pressure you should see a significant bulge in the sidewall of the tire between the whell and the ground, one pound can make a big difference in smaller tires. I suggest testing low pressure in your tires in your driveway, looking for the sidewall bulge at different low pressures. Do not try tight turns or spin donuts with low pressure!
Smiley is offline   Reply With Quote
Old July 18th, 2010, 01:00 PM   #25
xNewhaven11
Four Wheel Drive
xNewhaven11's Avatar
Send a message via AIM to xNewhaven11 Send a message via MSN to xNewhaven11
You will be fine.
You will have fun, you won't know until you try it though.
xNewhaven11 is offline   Reply With Quote
Old July 18th, 2010, 01:04 PM   #26
scramblerman72
Moonlight stomper
Jim I am going next weekend 25th come up and u can lead.. And remember the right side was where you pulled me of the 2nd hill where my BOA wasn't good enough for my speed..lol
Old July 18th, 2010, 01:21 PM   #27
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
friend of mine run up there with me and he has an identical truck as to what you described and the key was 6 psi front 8 psi rear and he had brand new bfg at not a very good tire in my opinion but i only pulled once when he thought the water hole was a good idea i think once you learn how the work the skinny pedal with those tires you will do fine and be happy
HPandThrottle is offline   Reply With Quote
Old July 18th, 2010, 01:41 PM   #28
ZJeepMI
ZJeepMI's Avatar
I have ran almost every hill out there in my dads Rubi (Rear LSD, or locker if needed) on 33" M/T in 2wd. My grand cherokee (5.2l, open diff) on 31" A/T's is absolutely useless in 2wd, every time I got on it to get some momentum the tires broke lose and i didn't go anywhere. But then again, I can hardly climb a curb in that thing without making a smoke show
I would imagine with some weight in the bed of your truck, you could probably keep traction with the V6 and it would be fun out there though. Worth a shot for sure, even if you do have to get pulled out a few times, it would still be a blast.
ZJeepMI is offline   Reply With Quote
Old July 18th, 2010, 02:11 PM   #29
hondadirtracer
Skymaster
hondadirtracer's Avatar
Ok guys, thanks for all of the advice so far. whiterhino said that just a hitch pin in my hitch was not good enough for a tow point in the rear. Would it be ok to use one of these in a hitch like this except mine doesn't have all of that material removed for the one ball system. Or should I just get one of these? Sorry about all the questions. I would rather play it safe for when I do get stuck. I do already have a 4"x30' strap.
hondadirtracer is offline   Reply With Quote
Old July 18th, 2010, 02:45 PM   #30
scramblerman72
Moonlight stomper
Just get a normal incert take the ball out and put a clevis in its place
Old July 18th, 2010, 02:55 PM   #31
scramblerman72
Moonlight stomper
Just looked at your links, the last one is the best. And I won't ever use pin style clevis only screw in style so you don't have to worry about the pin coming lose
Old July 18th, 2010, 04:23 PM   #32
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
No, hitch pin is not good enough.
What is wrong with that?
Old July 18th, 2010, 04:27 PM   #33
jeepinRRT
jeepinRRT's Avatar
The sharp edges from the hitch mouth can cut the strap when pulling on a an angle, either up or down.
Old July 18th, 2010, 04:29 PM   #34
curt1656
Praise the lowered
curt1656's Avatar
Get a shovel.
Old July 18th, 2010, 04:42 PM   #35
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Shovel is a good tool to have.
Silver Bullet is offline   Reply With Quote
Old July 18th, 2010, 06:16 PM   #36
hondadirtracer
Skymaster
Originally Posted by curt1656 View Post
Get a shovel.
I actually have an old wwII folding shovel from my grandfather.
Old July 18th, 2010, 06:55 PM   #37
Ready4Wheelin
Ready4Wheelin's Avatar
The receiver with the threaded pin is best, don't get the pin with the clip.
And forget that tiny folding shovel, you'll only piss yourself off in a sweaty fury. Bring a full size flat shovel, since you have the room in a pickup.
Oh, and I seen a late 80's Crown Vic on top of test hill one year when I was there!
Ready4Wheelin is offline   Reply With Quote
Old July 18th, 2010, 06:58 PM   #38
jeepinRRT
jeepinRRT's Avatar
http://www.flemingoutdoors.com/littl...hannelid=FROOG
My favorite wheeling shovel
Old July 18th, 2010, 07:28 PM   #39
scramblerman72
Moonlight stomper
A pin isn't good enough for a hard pull as its just a 9/16 bolt persay and could bend with out the aid of the recever
Old July 18th, 2010, 08:56 PM   #40
As said, hitch pin by itself will bend and you can cut a strap. Yes, people do it but your choice of this http://www.tractorsupply.com/winches...hackle-1834119 is best.
A hitch pin style clevis can get twisted sideways and then all the load is on the 1/8" diameter. And as someone else posted, never pull on a trailer hitch ball. They've been known to break and then become a cannon ball.
Page generated in 0.45377 seconds with 83 queries
