castor for a scout dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2010, 05:18 AM   #1
darrell_49412
darrell_49412's Avatar
Default castor for a scout dana 44
was wondering if anybody knew what degree i should set the castor at on a dana 44 that came out of a scout , i know they came with 0 degrees thanks darrell
darrell_49412 is offline   Reply With Quote
Old July 16th, 2010, 09:40 AM   #2
JimNut
JimNut's Avatar
in general you want to have around 4-6 degree's of positive caster. Castor is what causes the steering to return to center so without it driving gets a bit scary.
JimNut is offline   Reply With Quote
Old July 16th, 2010, 12:55 PM   #3
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
jim nut is correct. but I would look up the stock castor for the vehicle it's going into set the C's to that, then adjust from there after setting your pinion angle.
Old July 24th, 2010, 11:37 AM   #4
95geo
newbie
95geo's Avatar
Depending on what kind of steering you're using, I'd set it up for between 6 and 10 degrees positive. Anything less than 6 gets twitchy at speed.
Old July 25th, 2010, 03:34 PM   #5
PavementPounder
PavementPounder's Avatar
I agree with 6 degrees being the minimum.
Old August 20th, 2010, 02:46 AM   #6
darrell_49412
thanks for the help guys , i forgot i even posted this on here untill today when i went to work on the jeep , cant wait to get it done and go play
thanks darrell
Page generated in 0.18498 seconds with 41 queries
