Best Gears for Mudding - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2010, 12:04 AM   #1
bigmike7272
Default Best Gears for Mudding
I plan on building a mudding rig out of my 1991 Ford Ranger Extended Cab. It has the 2.9L V6 with a 5-spd manual tranny. I plan on goin with 33x12.5 inch tires. It has a Dana 35 front end and a 7.5" rear end. I was planning on putting either 4.13 gears or 4.56 gears but I'm not sure which one is better. Currently I have the 3.73 gears. What's your guys's opinions on what gears would be the best.
bigmike7272 is offline   Reply With Quote
Old July 16th, 2010, 12:37 AM   #2
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
4:56 but still going to suck as a mud truck as you need horse power and wheel speed to be a good mud truck or low gears and big tires.. You won't have either.. But .more gear will help the V6 out
scramblerman72 is offline   Reply With Quote
Old July 16th, 2010, 04:45 AM   #3
Yota Bill
x2
if you want a mud truck, your best bet is to consider a V8 swap and then run a somewhat higher gear ratio for wheel speed, but if the engine swap is not feasible, go for the lowest gear ratio, that will help you keep the tires turning...you arent going to be throwing mud in the air, but you may not get stuck as easily
if you do decide to swap in a V8, then also consider an auto trans, they work better then a manual for a mud truck since there is less lag between gears, and no clutch to get packed full of mud
Old July 16th, 2010, 05:59 AM   #4
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
X2 on the auto! I'm switching right now in my blazer, only really had 2nd gear because of the extremely low first gear. When mudding gears are your friend!
Old July 16th, 2010, 10:59 PM   #5
bigmike7272
thanks for the input guys. doy you think that 5.13 may be a better choice if i choose not to do a v8 swap?
Old July 17th, 2010, 10:12 AM   #6
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
don't waste your time on those axles. You'll just break them. by time you spend the money on gears and set up kits for them you could have bought some biggger axles and a v-8 to drop in. take $700 or so and find an old rotted out donor truck and take the drivetrain out of it and put it in the ranger or just swap the body.
Old July 17th, 2010, 02:04 PM   #7
scramblerman72
Moonlight stomper
If you plan on leaving it on 33's and a V6 just put in 4:56's and have fun but when the mud bug hits full on. Then build somthing else and keep the toy ranger or sell it to fund the 1ton mud truck.. Don't wast your time on anything less then 1tons unless your never gona run more then 36' and a mild V8
Old July 17th, 2010, 07:01 PM   #8
bigmike7272
thanks for the input guys i'm looking for some more heavy duty axles. dana 44 maybe and i'm lookin for a small block 350
Old July 17th, 2010, 09:33 PM   #9
scramblerman72
Moonlight stomper
Dana 44's arn't that good for anything over 36's and arn't good for tosing money into so unless you go to 3/4 ton dana 44 that already has 4;10 or 4:56's (arn't stronger just bigger breaks and better gears and be bought for under 500) don't waist your cash on dan44's if your plans are for bigger then 35's or 36's
Old July 18th, 2010, 09:15 PM   #10
bigmike7272
ok how about dana 60's
Old July 19th, 2010, 12:41 PM   #11
Fraser
Fraser's Avatar
that's what he was referring to as 1 ton axles. 350 in a ranger? really?
Old July 19th, 2010, 11:38 PM   #12
bigmike7272
maybe not in the ranger. what do you guys think of toyota axles? It seems alot of guys really like the toyota axles and I have 4 toyotas laying around my house but only one has an engine and that's my daily driver. so what do you think of the toyota axles. all of the toyotas are 88-90 so they are the ifs versions
Old July 22nd, 2010, 10:42 PM   #13
SSA95slinger
Born again mud killer
SSA95slinger's Avatar
Yeah X2 on the chevy in a FORD ...WTF!!!!!!!! I have a nice healthy 289 Id sell you .. A guy on here had a C6 and 205 case for a couple hundo's.. Just add axles ,tires,and mud ...
SSA95slinger is offline   Reply With Quote
Old July 23rd, 2010, 05:21 AM   #14
Yota Bill
basically, for a BDMT, think big tires and high wheelspeed...that means a good BDMT has plenty of torque to get the tires spinning, and lots of horsepower to keep them spinning at a high speed. It would also need some hefty axles to handle the weight of the tires and the pure abuse that causes.
now, if your looking to play in the mud with this Ranger, and do it on the cheap, then just take a sawzall to the front fenders, ditch the bed, move the rear axle as far foward as possible, stick the biggest tires on it you can, and have fun
the best way to build a BDMT is to start with a 3/4 or 1 ton truck, preferably the older trucks, with a solid front axle. Then you already have the V8 and decent axles, lift it and add some tires.
Page generated in 0.24235 seconds with 65 queries
