Changing A/C Clutch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2010, 02:17 PM   #1
Drg racr
Drg racr's Avatar
Default Changing A/C Clutch
i think the a/c clutch on my 89 F150 is toast. I'm getting power to the compressor, but the clutch won't kick. I tried bypassing the low pressure switch as well.
How hard is it to change the clutch? Or should I just swap out the whole compressor? it still has R12 in it. I'm just looking for a cheap fix for now. I even thought of tapping a few screws into the holes in the clutch and lock the clutch up, but I don't want to ruin anything.
Drg racr is offline   Reply With Quote
Old July 14th, 2010, 04:23 PM   #2
Yota Bill
did you check the ground? test resistance of the clutch coil? use jumper wires to feed both positive and ground to the coil (engine off, of course)? do at least those tests before condemning it
Old July 14th, 2010, 04:24 PM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
It requires a puller, but the clutches aren't too bad to change, but i've only ever changed them on a bench.
Is the a/c comp at leat up near the top of the motor?
Old July 15th, 2010, 03:31 PM   #4
Drg racr
Drg racr's Avatar
I actually wired the compressor directly from the battery and no difference. I'll double-check the ground.
The compressor is right on top of the motor, easy access.
Old July 15th, 2010, 03:41 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
If the compressor is original, I would go with a whole unit. The clutches can be a PITA to change, especially a 21 year old one. Time or money, take your pick.
Old July 15th, 2010, 03:43 PM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
Not sure on the fords, but I have done the one in my jeep. (piece of cake) Just go rent the clutch removal tool and pick up a new clutch.
Old July 15th, 2010, 04:42 PM   #7
Fuel Fire Desire
Mall Crawler
Fuel Fire Desire's Avatar
On an old car I had, my A/C clutch started making a bunch of noise/ engaging hard. As a last ditch effort before routing the belt as if A/C wasnt installed, I hosed the clutch down with WD-40. I stuck the red straw in between the spring, and emptied a 1/4 can into it.
Worked flawlessly after that.
Probably not the same issue, but just a thought.
Fuel Fire Desire is offline   Reply With Quote
Old July 15th, 2010, 05:23 PM   #8
Bones
Bones's Avatar
I think i have a complete unit I can sell you cheap
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 16th, 2010, 01:39 PM   #9
Drg racr
Drg racr's Avatar
Alright, a man that speaks my language, CHEAP!!!
PM me with the details. Thanks
Old July 25th, 2010, 02:22 PM   #10
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
That compressor does NOT require a puller. All you need are snap ring pliers. Really easy to change, even on old vehicles. I've changed several.
DeRanged mudder is offline   Reply With Quote
Page generated in 0.22575 seconds with 53 queries
