ranger body on 78 bronco frame - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2010, 11:43 AM   #1
chumwon
Big Boys Toys Co.
chumwon's Avatar
Default ranger body on 78 bronco frame
Well i was thinkin about this alot and it doesnt seem all that difficult but what do i know. I have a 99 extended cab shortbox ranger (which is my DD)that seems to be barley livin. Basically the whole drivetrain in general blows! Then i have a 78 bronco mud truck sittin in the back fourty with a flawless drivetrain but barley even a body. Is it possible to put my ranger body on the 78 frame with all the drivetrain? Please let me know what you guys think about it and how itd be done. Thanks
chumwon is offline   Reply With Quote
Old July 11th, 2010, 01:26 PM   #2
Yota Bill
shouldnt be all that difficult...build some new body mounts, weld them to the frame so they match up to the stock body mount locations on the ranger body, and bolt it togethor....take alot of measurements first...I would start by removing the body and setting it aside, then putting the two frames side by side so you can easily transfer measurements, and check clearences for the body to fit around the engine, tire locations, etc.
of course, there are going to be other things to consider...which master cyl to use, and if you decide to use the master off of the fullsize (best bet) then you need to figure out how to mount it (not difficult), radiator placement, wiring, etc....if the Ranger has power windows, locks, etc., then you need to figure out which way you want to resolve that, since they are run by the body control module...same with wipers, air bags, ABS, etc...
mounting the body on is the easy part, making everything function correctly is going to take alot more research and planning.
Old July 11th, 2010, 01:32 PM   #3
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Tonka Toy and cheapthrillb2 have done it. Its doable
Old July 11th, 2010, 06:08 PM   #4
chumwon
Big Boys Toys Co.
chumwon's Avatar
hm doesnt sound to bad. bodys pretty easy like i thought but a few other little things. I dont have power windows or anything so no worry there. I was worried about the engine fittin in there but i think itll be alright. Thanks
Old July 11th, 2010, 06:17 PM   #5
Trail Junkie
iamfawkinwithyou
sawzall will make it fit
Old July 11th, 2010, 06:36 PM   #6
Mostly depending on your motor and trans option, you will have clearance issues with the heater box, trans tunnel, radiator, and the steering set-up, other then that it is not to bad.
Old July 11th, 2010, 06:58 PM   #7
chumwon
Big Boys Toys Co.
chumwon's Avatar
i have the t-18 which saves me a little room.
Page generated in 0.25175 seconds with 44 queries
