cranks but no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2010, 11:39 PM   #1
acemann28
Default cranks but no start
i just put a diffrent motor in my truck it cranks over but dose not start i am hearing a poping sound when i give it some gas . 1995 302 efi . i am about ready to junk the truck. thanks
acemann28 is offline   Reply With Quote
Old July 10th, 2010, 12:26 AM   #2
AceMon
Could've had a v8
AceMon's Avatar
What did you try troubleshooting already? More info would be helpful. Double check your plug wiring and timing and then go from there.
AceMon is offline   Reply With Quote
Old July 10th, 2010, 12:45 AM   #3
rentalrider
rentalrider's Avatar
A LOT more info would be a good start. For all we know you just dropped that 302 in an isuzu. Same yr engine? New computer or old? etc, etc, etc.
Are cylinders getting gas? (wet plugs) Pressure at the rail? Unless they changed there should be an orifice to check pressure on passenger side fuel rail. I run an injected 302 but without more info, they're all just guesses.
Old July 10th, 2010, 01:06 AM   #4
Yota Bill
the popping would probably indicate a timing issue...reset distributor/recheck plug wire for correct firing order first
did you hear this engine run before putting it in the truck?
Old July 10th, 2010, 11:22 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
ditto,
also the firing order on HO 302s is different, maybe the plug wires need swapped around to the correct location
Old July 10th, 2010, 12:33 PM   #6
acemann28
it was the timing , now i just have to get it running correct. thanks
Page generated in 0.17099 seconds with 41 queries
