Bronco/F150 Windshield Swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2010, 10:42 PM   #1
The Kaiser
The Kaiser's Avatar
Default Bronco/F150 Windshield Swap
The windshield in my 91 bronco is junk and I need to replace it, and I'm looking to save as much cash as possible. F150s are much more common in the u-pull-its around here than broncos, and I want to know if any of you have ever swapped a windshield from one to the other, or whether they're compatible. I think they should be, since the bronco and f150 fronts are almost identical in most aspects for this model year. Thanks in advance for any info.
The Kaiser is offline   Reply With Quote
Old July 8th, 2010, 02:03 AM   #2
masterbeatty
masterbeatty's Avatar
thhere the same. ive never know many people to have luck with doing this though, i guess just take your time and be careful.
Old July 8th, 2010, 02:07 AM   #3
Windsorf350
Rusty Racing
Windsorf350's Avatar
i did mine with a base ball bat and a sledge hammer if that tells you anything that glue that holds them in is tough
Windsorf350 is offline   Reply With Quote
Old July 8th, 2010, 02:33 PM   #4
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
we got a curved knife we use to cut the glue when we swap them. my old man used to work at a glass shop changing windshields. where in GR are ya?
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old July 8th, 2010, 08:48 PM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
used windshields almost always crack when being removed, good luck
Old July 9th, 2010, 10:35 AM   #6
The Kaiser
The Kaiser's Avatar
I'm pretty confident that I can cut one out without too much of a problem, but I was thinking about paying someone who actually knows what they're doing to install it in my truck.
Old July 11th, 2010, 01:12 AM   #7
The Kaiser
The Kaiser's Avatar
Well, as it turns out I cannot cut one of those things out. At least not without cracking it in the process. I used a nice knife to make a starter hole, then used .020 piano wire to cut the sealant. Problem is, there are certain places where the wire refuses to cut and just breaks instead, so in attempting to get past this with a knife, I kept cracking the glass. How do I get past that? I did have a friend helping me, but he's just as clueless as I am.
Old July 12th, 2010, 09:24 AM   #8
fsumotorhead
N8KVB
I replaced two windshields in my 93 ford, i think they were only like $130 for new glass installed.
If you have comp on your truck, the detuctable for glass is only about $50 usually.
Old July 13th, 2010, 12:25 PM   #9
BOGDOG
BOGDOG's Avatar
I have swapped them on Broncos it a couple times. Only thing I can say is go slow and be careful. I started the cuts with a razor knife then just kept cutting deeper using a sharp thin flexible knife to get all the way thru.If you are going to pay someone to install it it might be worth it just to pay for the glass as well. I am having one of my 4Runners done for $125
Old November 5th, 2010, 09:11 PM   #10
cameron351
They are the same, almost every single part thats on an F150 can go on a Bronco as long as they are the same year, or at least the same body style. The only exceptions are the back panels since the Bronco doesn't have a bed, the tail gate, and the topper.
cameron351 is offline   Reply With Quote
Old November 9th, 2010, 10:37 AM   #11
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
i agree with above, worth the $ to just have a new one installed.
big_ol_bronco78 is offline   Reply With Quote
Page generated in 0.37503 seconds with 56 queries
