460 build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2010, 12:38 AM   #1
masterbeatty
masterbeatty's Avatar
Default 460 build
im looking to build a 460 to put in a bronco and im wondering what some of yall have built and liked specs? just looking for info at the moment. cams? valve train? pistons? intake? carb?
Old July 7th, 2010, 07:37 AM   #2
s.hembree
s.hembree's Avatar
What's your realistic budget? What do you intend to do with the Bronco?
Old July 7th, 2010, 10:57 AM   #3
masterbeatty
well it would be a spread out build so money here and there when i get it. sand,mud and a a little street. more than like on tons and a 40+ tire
Old July 7th, 2010, 11:22 AM   #4
Paperman
Paperman's Avatar
Cost could be $1000-$10,000+. Remember to lay a plan and only buy parts once. If you want more inches dont dump a ton of coin into heads you cant get pistons for. You looking for a never open the cover deal or a healthy engine that will need to be looked over every now and then?
Paperman is offline   Reply With Quote
Old July 7th, 2010, 11:25 AM   #5
Windsorf350
Rusty Racing
Windsorf350's Avatar
i would just freshen it up hoan cylenders new rings decent set of aluminum heads and a good intke and carb and you get a decent powered 460
Windsorf350 is offline   Reply With Quote
Old July 7th, 2010, 01:17 PM   #6
masterbeatty
what do you mean by decent power? i was hoping for around 400 to 500hp from what i hear 500 is fairly easy to achieve from a 460
Old July 7th, 2010, 01:33 PM   #7
Wheelman
Extreme Mudder
Wheelman's Avatar
i just Google 500hp 460 found this article lot of info in it.
http://www.carcraft.com/techarticles...ild/index.html
Wheelman is offline   Reply With Quote
Old July 7th, 2010, 02:42 PM   #8
Paperman
Paperman's Avatar
You cant just bolt on a set of Al heads and an intake and expect it make 5 bones. Give a dollar amount on the total and you can make a plan. A set of cheap ProComp heads may look cool but for a few more dollars you can get a head that works. Cam and intake choice should be looked at after cubes and RPM are figured. If it was me I stuck good money in the bottom end and swing the shit out of it. With good stuff in the bottom and a mid 4.?? stroke. Next year buy a good set of preped heads to make us of the bottom. If you spend money on top first you cant use it until you need it (RPM or CuIn).
Old July 7th, 2010, 04:06 PM   #9
Porkchop
Porkchop's Avatar
if it helps the budget there's a 460 posted in the parts section for $150.
it may be easy to build up but the 400 hp is easy to get to. the heads make the engine in the case of 460s. they need to breath. if you go with the stock 2.02 heads use stainless valves and 292 In 300 ex with about a .560 lift at the lobe. the best cam is the stock cobra jet cams with the hydraulic lifters(about .490 lift at the lobe). the stock super cobra cam is a solid unit and a pain to keep adjusted in. the com cams folks make a few nice cams for high torque if you want good low end.
Porkchop is offline   Reply With Quote
Old July 7th, 2010, 05:26 PM   #10
IDIeselman
IDIeselman's Avatar
400-425HP 460ci
Intake System:
750cfm Holley DP professionally calibrated for your application
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
D0VE heads with mild port job and chambers polished
(315ish/180-ish cfm flow @.600)
Intake valve size 2.08
Exhaust valve size 1.65
Stock rockers.
Short Block:
Comp Cam XE262H Hydraulic flat tappet cam or equivalent
(Specs:262/270 adv., 218/224@.050, .513/.520, 110 LSA)
Compression around 9.5:1
Stock crank
Stock rods with good bolts
Standard volume oil pump
Stock oil pan with windage tray
Exhaust:
1 7/8" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
91-octane. Keep redline to 6000 rpm.
425-450HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished, and port match
(315-ish/180-ish cfm @.600)
Roller rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5443 and Exhaust Lobe 5203
(Specs:268/280 adv., 224/230@.050, .524/.544 lift, 110 LSA)
Stock crank
Exhaust:
Summary:
450-475HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished and port match
Roller rockers.
Short Block:
Comp Cam XE274H Hydraulic flat tappet cam or equivalent
(Specs:274/286 adv., 230/236@.050, .562/.565, 110 LSA)
Stock crank
Eagle I-beam rods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6500 rpm.
475-500HP 460ci
Intake System:
750cfm Holley DP Carb professionally calibrated for your application
Cylinder Heads:
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
Roller rockers.
Short Block:
Compression at 9.8:1
Stock crank
Eagle I-beam rods
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91 octane. Keep redline to 6500 rpm.
500-525HP 460ci
Intake System:
Cylinder Heads:
TFS street heads with mild clean-up
Roller rockers.
Short Block:
Compression around 10.0:1
Stock crank
Eagle I-beam rods
Exhaust:
Summary:
The list goes on and on. This should get you started.
Old July 7th, 2010, 08:24 PM   #11
masterbeatty
wow thankyou idi and to everyone else that posted so far.
i do have a 460 with a weiand stealth intake but thats about it. i dont think it even turns over at the moment. so a complete rebuild will be needed.
Old July 19th, 2010, 01:12 AM   #12
Fraser
Fraser's Avatar
my buddy is putting together something wild now, but before he just put on the non emissions timing set and just his holly, intake and a cheap summit cam and it got around pretty good. only complaint he had is that he ran out of r's w/ the cam he ran
Old October 18th, 2010, 07:40 AM   #13
Tuff_F150
Tuff_F150's Avatar
make sure to use a early/adjustable timing set. later ones retard the cam timing 8 degres. i have a 466, lunati bracketmaster cam, performer intake, 770 truckavenger,keith black pistons d3ve heads good port job (soon to be either d3ve's with big valves and wicked port work or c9ves with same work) its almost 10 to 1. runs great on good pump gas.
Tuff_F150 is offline   Reply With Quote
Page generated in 0.34796 seconds with 62 queries
