tube fenders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2010, 08:24 PM   #1
jeepnxj96
jeepnxj96's Avatar
Default tube fenders
I made some tube fenders for a buddies jeep.....he took the sheet metal to finish up on his own......hope to have some pics of them mounted soon. ohhhh the are 3" higher than stock.
trimmed 3" off the bottom of the hood
the tubework
Old July 6th, 2010, 08:41 PM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
Looks good Ricky
Old July 30th, 2010, 08:17 AM   #3
jeepnxj96
jeepnxj96's Avatar
here are some pics of them finishished up
on a jeep with 4" of lift and 37's
Old August 15th, 2010, 11:29 AM   #4
chrsnrwd
chrsnrwd's Avatar
They held up to this.
chrsnrwd is offline   Reply With Quote
Old August 16th, 2010, 06:21 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
looks good, I like the marker lamps
Old September 12th, 2010, 08:22 PM   #6
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
How big of tires do you have on this now that you have the tube fenders on, with a four inch lift it looks like 37?, what happens in the rear, are you getting a lot of rubbing in the rear?
dougstephvoor is offline   Reply With Quote
Old September 15th, 2010, 07:57 PM   #7
jeepnxj96
jeepnxj96's Avatar
those are 37's he has on with a 4 inch lift, the front axle has been pushed foward a bit, I think around an inch or so as well as the rear axle being moved back an inch or two. He just trimmed out the flares on the rear and a little sheet metal if I remember corectly. He has a set of rear cornerguards I had bent up for him, they just need finished off, but haven't had much time. the last I knew he thought about lowering the jeep another inch because of the clearance he gained with the front fenders. Hope this helps
Old September 15th, 2010, 08:04 PM   #8
dougstephvoor
Supreme Chancelor!
Thanks for the info, I would like to get to 35's and would rather do tube fenders and possible mods to the rear quarter, with out going up 6-1/2" Flopin, is not my favorite thing, and I do not want to go to full width axles. Good info, thanks.
Old September 15th, 2010, 09:07 PM   #9
shockfuel
When in Rome...
shockfuel's Avatar
Send a message via AIM to shockfuel
Those look sharp as shit!
shockfuel is offline   Reply With Quote
Old September 21st, 2010, 06:29 PM   #10
jeepnxj96
jeepnxj96's Avatar
Thanks
Old September 23rd, 2010, 04:56 PM   #11
judgemikdredd
its a YJ
judgemikdredd's Avatar
they look real good!
what bender did you use? what tube did you use?
judgemikdredd is offline   Reply With Quote
Old September 23rd, 2010, 08:44 PM   #12
motox168
Bare Bones Offroad
motox168's Avatar
Ricky uses a jet tripod bender
motox168 is offline   Reply With Quote
Old September 27th, 2010, 05:38 PM   #13
funandgames
funandgames's Avatar
nice job with the fenders
Now make him something to hold his battery down
funandgames is offline   Reply With Quote
Old September 27th, 2010, 07:52 PM   #14
chrsnrwd
chrsnrwd's Avatar
I put the stock one back in, but had to shift it over a little and drill new mounting holes.
And they are actually pipe fenders
Old September 30th, 2010, 07:03 PM   #15
jeepnxj96
jeepnxj96's Avatar
hey pipe, tube, it is all manufactured the same way, just minus one process and about 1/2 the price
Page generated in 0.30504 seconds with 69 queries
