WTB: 6-lug 3.42 14 bolt SF rear axle for 95 GMC truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2006, 04:23 PM   #1
FixinMyTruck
Default WTB: 6-lug 3.42 14 bolt SF rear axle for 95 GMC truck
I need a "new" axle for my 95 GMC truck. It's a light duty 2500 with 6-lug semi-floating 14 bolt (nothing like a "real" 14 bolt).
Need something that will bolt in with no mods, and inexpensive.
Prefer in the Kalamazoo area.
Thanks
FixinMyTruck is offline   Reply With Quote
Old August 11th, 2006, 05:13 AM   #2
crassell
crassell's Avatar
Whaich one are you?
4x4, semi-floating, 6 wheel bolts, 3.42 ratio GU6
4x4, semi-floating, 6 wheel bolts, 3.73 ratio GT4
4x4, semi-floating, 6 wheel bolts, 4.10 ratio GT5
4x2, semi-floating, 6 wheel bolts, 3.42 ratio GU6
4x2, semi-floating, 6 wheel bolts, 3.73 ratio GT4
4x2, semi-floating, 6 wheel bolts, 4.10 ratio GT5
4x2, semi-floating, 6 wheel bolts, 4.56 ratio HC4
crassell is offline   Reply With Quote
Old August 11th, 2006, 07:07 AM   #3
lt1yj
My brother has one with a 3.73 ratio. He's between Schoolcraft and Three Rivers. He's asking $150 for it drum to drum. He has the matching front diff as well. $250 for both. PM for his contact info
lt1yj is offline   Reply With Quote
Old August 15th, 2006, 08:58 AM   #4
BIG AL
GO BIG OR GO HOME!
BIG AL's Avatar
Default 14 bolt
Ive got 1 .6lug 14 bolt 3.42 rear out of 94 chevy pickup $350
BIG AL is offline   Reply With Quote
Old August 17th, 2006, 07:26 PM   #5
Strangler
Strangler's Avatar
I left one out at "justcuz's" in Adrian. Im sure he'd let you have it if you need it. Came out of a running truck that I took the engine from.
Page generated in 0.28031 seconds with 38 queries
