7.5 cracked exhaust manifolds - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2010, 06:49 PM   #1
redram98
redram98's Avatar
Default 7.5 cracked exhaust manifolds
my buddys truck has a pretty bad crack in the exhaust manifold, bad enough to melt the spark plug wire on #5 i believe. my question is if i were to fill it w some nickle w/o removing from the engine will i cause any damage? if i were to try this fix, i will be heating manifold then tig welding w/ prob 55/45 rod.
redram98 is offline   Reply With Quote
Old July 6th, 2010, 07:45 PM   #2
Yota Bill
the 460 is known for cracked manifolds...best bet is to replace them...if you try to fix it, it will break again
Old July 10th, 2010, 01:20 PM   #3
redram98
redram98's Avatar
o i know it. i would personally replace, but its my buddys truck. It needs rings badly, and there are plans of rebuild this winter but he needs it this summer to pull his boat. figured we could cheat for now then replace when the engines out.
Old July 10th, 2010, 11:49 PM   #4
Yota Bill
in that case, cheat away
Page generated in 0.14940 seconds with 35 queries
