adding a turbo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2010, 04:38 PM   #1
bjkttr
bjkttr's Avatar
Default adding a turbo
I have a f250 with a 390 with the following
390 .030 over flat top forged pistons
2. balanced crank and rods
3. 428 heads ported and polished intake and exhaust ports
4. ported intake to match the gaskets.
5. .512 lift 292 duration comp cam.
6. 750cfm edelbrock carb
I am thinking of adding a turbo. What other mods will I have to make so that I don't cause any damage to the engine. And what kind of turbo every one would recommend.
bjkttr is offline   Reply With Quote
Old July 5th, 2010, 04:41 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
i would get the best exhaust valves you can buy. i was looking into putting twin turbos on my 65 buick skylark a while back and that was the number one thing that everybody told me!
Old July 5th, 2010, 04:45 PM   #3
PCK_4xCustoms
r00t4r3d
PCK_4xCustoms's Avatar
Send a message via AIM to PCK_4xCustoms
I like the idea and have been throwing it around in my head to do a twin turbo setup on my 5.7l
sorry I don't have any info to help, just wanted to get in on the thread so I can find it later
Good luck
PCK_4xCustoms is offline   Reply With Quote
Old July 5th, 2010, 05:03 PM   #4
1978f-150
village idiot
1978f-150's Avatar
stud the heads if you haven't done it yet
1978f-150 is offline   Reply With Quote
Old July 5th, 2010, 05:18 PM   #5
v2win
v2win's Avatar
How much boost do you plan on running?
What is the compression ratio?
How is your fuel delivery system?
v2win is offline   Reply With Quote
Old July 5th, 2010, 05:24 PM   #6
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
It really depends on what boost levels you are planning on running. Any decent motor can run on a 5psi boost, they already are at 14.7 anyway just from the atmosphere. Pick up a copy of 'Maximum Boost' by Corky Bell, that will tell you just about everything you want to know
Motorcitydak is offline   Reply With Quote
Old July 5th, 2010, 05:30 PM   #7
bigblockford79
Big Block Ranger
bigblockford79's Avatar
You might also want to look into a pro-charger system as well, which is basically a belt driven turbo.
Old July 5th, 2010, 05:34 PM   #8
chadcooper55
ya it is at 14.7+- but it is the same on the outside of the motor so it doesnt actually have 14.7 lbs of pressure differential.
Old July 6th, 2010, 12:00 AM   #9
deathbypsi
Brian R.
deathbypsi's Avatar
You will need to know what compression you have first. If its 10.0-1 or higher you might be better off looking into dropping compression first.
The cam has to much duration for a turbo setup. You want less duration and very little over lap to prevent blowing your boost right out past the open exhaust valve. Wide LSA numbers in the 112 min to around 117 work best.
I have never seen anybody get one of those carbs to work on a turbo setup{or blow thru blower}. I would say swapping to a Holley built for blow thru is your best option.
You will need a dam good fuel system to make all of this live if you go thru with this. Do not skimp on a cheap or small fuel pump and a good boost referance regulator.
Old July 6th, 2010, 11:05 PM   #10
bjkttr
bjkttr's Avatar
Default turbo
I just wanted to thank everyone for the advice. I think that I will wait for the next project to run a turbo. My wife keeps wanting to claim this truck anyways.
Page generated in 0.19411 seconds with 53 queries
