easiest start/run circuit 85 K20 ASAP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2010, 02:22 PM   #1
ssdeuces
ssdeuces's Avatar
Default easiest start/run circuit 85 K20 ASAP
I made the mistake of mentioning that we didn't need all this wire under the dash for a dedicated mudder so....my step-daughter took care of everything....now no start/run. Does anybody have the shortcut? I could use a little advice...most of the connectors are still plugged in on the switch...colors would be handy.
Thanks in advance.
Ken
ssdeuces is offline   Reply With Quote
Old July 3rd, 2010, 03:23 PM   #2
spgirard30
spgirard30's Avatar
I purchased a painless harness for this model truck and in the install manual it tells you the factory colors. you can try going to their website and downloading the manual.
spgirard30 is offline   Reply With Quote
Old July 3rd, 2010, 03:29 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
ouch,
sounds like you need power to the ignition switch.
then you need keyed power to the distributor and
then a wire to crank the starter.
if you want alt wires then you have to pick a keyed on circuit that runs through a light bulb from the brown wire on the alt.
Yetti
Old July 3rd, 2010, 05:57 PM   #4
ssdeuces
ssdeuces's Avatar
yes I do need all of these things...what color wires am I looking for to feed the switch, what wire from the switch goes to what plug on dist? I'll just run new wires, but from where on switch? I have spinal issues and can't lay under the dash.
Page generated in 0.24069 seconds with 35 queries
