67 M715 buildup - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2010, 10:47 AM   #1
spgirard30
spgirard30's Avatar
Default 67 M715 buildup
as requested I am going to post a build thread for my 715. I purchased a few years ago while I was working in Afghanistan and only have a few weeks a year to tinker with it in between visiting family and friends. I think with the time I have had to work on it I have accomplished a lot.
This is how I got the truck.
bone stock truck with only a little surface rust. This was used as a fire truck somewhere in the midwest and stored inside. The bed has some holes cut in the floor where that ran pipe through for the water tank but that will get patched at some point. I think it has around 27,000 miles on it.
spgirard30 is offline   Reply With Quote
Old July 3rd, 2010, 10:52 AM   #2
spgirard30
spgirard30's Avatar
Once I got home and played with it, it was smoking pretty bad and just didnt seem to run very strong. I drove it maybe 20 miles and then the balancer broke. someone replaced the key on the crank and it had enough play on it to eventually break lose.
I intended on keeping the truck stock but looking into trying to just rebuild the head on the 230 changed my mind. parts were next to impossible to find and if you found usable parts they were a small fortune.
so I parted out the entire drivetrain and decided to go big.
Old July 3rd, 2010, 10:57 AM   #3
spgirard30
spgirard30's Avatar
I stripped it down to the frame to remove all the old fuel and brake lines. It also made it a lot easer to get the rockwell axles under the frame. While I was at it I tore apart the rear leaf packs and stripped, painted, and coated with slip plate.
Old July 3rd, 2010, 11:03 AM   #4
spgirard30
spgirard30's Avatar
I had some 1.5 inch body mounts made at a machine shop out of urethane to put the body back on, that seemed to work okay. I replaced every single bolt with new grade 8 bolts and some grade 9 in the suspension and steering arms.
Old July 3rd, 2010, 11:11 AM   #5
spgirard30
spgirard30's Avatar
I am using all cobalt autometer gauges. I have some lowback suspension seats and a flaming river tilt column.
Wheels and tires are both military take offs. I intially went with the 48 inch XL's but they just were to big and I didnt want to have to lift the truck anymore so I went down to the 46 XML's. The rims are some recentered military 2 piece wheels that look great on the truck.
Old July 3rd, 2010, 11:11 AM   #6
88WRANGLERYJ
jeeper
88WRANGLERYJ's Avatar
nice rig
88WRANGLERYJ is offline   Reply With Quote
Old July 3rd, 2010, 11:23 AM   #7
spgirard30
spgirard30's Avatar
now my drivetrain is a 454 with a 400/205 combo. I have a 505 being built that I am copying out of chevy high performance mag that got 580hp/600ftlb at the crank. But for now I just have a takeout motor in there.
Old July 3rd, 2010, 11:25 AM   #8
spgirard30
spgirard30's Avatar
the very last thing I did on my last vacation was get the motor running.
Old July 3rd, 2010, 11:32 AM   #9
spgirard30
spgirard30's Avatar
I still need to complete the wiring for all the lights and stuff, run fuel and brake lines. I need brakes also, I found a company that makes wheel brakes for the rockwells. I need steering also but havent decided on full hydro or just assist. leaning towards full hydro since this wont be on the road hardly at all.
I am sure I missed a lot of info so if you have any questions just ask. I did everything here myself except weld the motor mounts to the frame.
here is the link to all the pictures I have up to its current state.
http://s853.photobucket.com/albums/a...ungirard/M715/
Old July 3rd, 2010, 11:41 AM   #10
95geo
newbie
95geo's Avatar
This thing is cool!
Old July 3rd, 2010, 11:43 AM   #11
capone
capone's Avatar
Thank you for serving.
Very Cool. Did you buy that from Dennis?
capone is offline   Reply With Quote
Old July 3rd, 2010, 11:45 AM   #12
spgirard30
spgirard30's Avatar
Yes I believe the PO was named Dennis, it has been a few years though.
Old July 3rd, 2010, 11:47 AM   #13
capone
capone's Avatar
I'm pretty sure I remember this one at his house. I'm sure he will chime in.
Old July 3rd, 2010, 12:01 PM   #14
fabricator
throttle jockey
fabricator's Avatar
looks great. i just recently purchased a 68 m715 with dana 60 and 14 bolt combo with 350, sm465. mines going to be a winter project. i think i'm going with 40inch mtrs and throw in a nv4500 trans.
fabricator is offline   Reply With Quote
Old July 3rd, 2010, 12:08 PM   #15
spgirard30
spgirard30's Avatar
I wish I would have went with the 60/14b combo instead. Are you a member of www.m715zone.com thats a great site for any tech info or parts needed.
Old July 5th, 2010, 12:38 AM   #16
spgirard30
spgirard30's Avatar
here is a pic of me with the truck, I am 6'1'' There is no motor in the truck but the springs are so stiff they only settled about half an inch once the motor was in.
Old July 5th, 2010, 10:41 AM   #17
fabricator
throttle jockey
fabricator's Avatar
yes, i just registered on m715zone. i hope to drive it around a lot in the summer. hopefully with the 60-14 axle combo and a nv4500 swap it will be a little more road friendly.
Old July 5th, 2010, 12:58 PM   #18
spgirard30
spgirard30's Avatar
there is a member there named ryanroo who built a really nice truck with the 60/14 combo and an NV4500 behind a big block, he was a fabricator at avalanche engineering when he built the truck. I think the title of his build thread is found one, its worth the time to go through all his posts.
Old July 5th, 2010, 07:36 PM   #19
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
what a beast! looks awesome.
Old September 26th, 2010, 04:43 AM   #20
spgirard30
spgirard30's Avatar
No progress on the truck besides ordering parts. I have 3 weeks in February home so I will get it driving then. I decided to go the route of full hydro steering. I have a PSC rockwell kit waiting for me in the shop. I also have been talking to red barn customs to put me together brake kits, driveshafts and all the flanges I need. Those will be on order soon. All that will be left is plumbing the fuel lines, brake lines, and button up some wiring for all the lights and guages.
Page generated in 0.37906 seconds with 84 queries
