94 Bronco fuel filter change help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 2nd, 2010, 03:17 PM   #1
cglenn
Default 94 Bronco fuel filter change help
94 Bronco, 5.8. I'm trying to replace the fuel filter and I have the little metal tool thing to take the lines off, however one is being a bitch and won't come off. I've tried prying the thing loose but it won't budge. The lines are SS braided and the filter isn't rusty. Anything I can do to fix this real quick?
cglenn is offline   Reply With Quote
Old July 5th, 2010, 12:33 AM   #2
Never_Evil
Try using PB Blaster and hit it into the retention spring. Try and rotate the filter to make sure it is not seized to the lines.
Stupid question, but did you pull out the White plastic clips first?
Just because it is not rusted, does not mean it is not corroded.
Old July 6th, 2010, 07:43 PM   #3
Yota Bill
sounds like he is talking about the style with the metal spring clip that is inside of the line, since the ones with the plastic clips dont need any special tools
make sure you push the line on as far as you can, and hold it there, while pushing the tool into the line...you need to get the clip away from the flare on the filter and then get the tool under the clip...if you start prying it you will damage the clip and possibly the line as well
Old July 6th, 2010, 07:51 PM   #4
hmmm, my 96 bronco has the plastic clips as well as my 96 f250.
Old July 7th, 2010, 08:38 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
Ford changed the fuel system lines around constantly, and still do, must be a job security thing.
any way, like mentioned above push the line on all the way insert tool and give it a good hard jerk back.
Page generated in 0.16876 seconds with 38 queries
