Welding Vertical - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2010, 10:05 PM   #1
OldSlowReliable
extra on the SLOW
OldSlowReliable's Avatar
Default Welding Vertical
Those of you who weld on frames and such, got any tips for welding on a wall situation? (or the outside wall of the frame for rocksliders)
I have eliminated 90% of the welding that could have been done in that kind of situation because I know the welds won't be all that great..
It will be a 3/16" mounting plate being welded around all 4 edges to rusty 1/8" frame tubing... I will be grinding the rust off tomorrow pre-welding
OldSlowReliable is offline   Reply With Quote
Old June 30th, 2010, 10:16 PM   #2
kj kyle
kj kyle's Avatar
search it on youtube. their are a few vids that show how to make nice uphill welds.
I dont want to start the debate here, but I've heard downhill welding is ok on 3/16".
kj kyle is offline   Reply With Quote
Old June 30th, 2010, 10:52 PM   #3
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
I hate arc welding in this position ... I hope your mig or tig welding. ain't so bad with a good ground and good clean metal.
Old June 30th, 2010, 11:03 PM   #4
redram98
redram98's Avatar
personally i would go down. too thin of material to do a verticle up. will most likely blow through the base material (frame) trying to weave a good upward bead.
redram98 is offline   Reply With Quote
Old June 30th, 2010, 11:17 PM   #5
OldSlowReliable
extra on the SLOW
90 amp HF Mig to the rescue! ;)
Yeah, I had that issue when welding on some patch panels a while back, although this area is significantly less rust-thinned.
So that covers the sides, what about the bottom edge? Just turn wirespeed/current down and hope for the best?
Old June 30th, 2010, 11:21 PM   #6
redram98
redram98's Avatar
are you weaving the top edge? if so whats your pattern
Old June 30th, 2010, 11:32 PM   #7
OldSlowReliable
extra on the SLOW
I'm not sure what you said...I'm a pretty half assed welder
Stupid people terms ;)
Old July 1st, 2010, 12:00 AM   #8
redram98
redram98's Avatar
right on. weaving is manual manipulation of the weld puddle, allowing you to put more filler material into the weld, without making multiple passes. thats how you get the (((((((((((( appearance of a weld. its tough for a beginner, but try looking this over. if all else fails just crank up the heat and give er hell
http://www.weldingtipsandtricks.com/...echniques.html
Old July 1st, 2010, 04:09 AM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I have better luck welding vertical bottom to top. make it like a sewing machine stitch and it goes easy. in corners it gets easier because you carry melted material up with the wire as you move the tip. works well in as thin as 18-20 gauge stuff. don't forget to grind everything clean where the welder touches.
Yetti
Old July 1st, 2010, 05:27 AM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Personally I prefer to do that with an arc or tig over a mig but I also use an arc and tig welder all day long. The only advice I have for you is watch the very front of your puddle, if it starts to dig stop welding and let it cool a Bit! Also if it is crowning up a lot in the shape of a V you are too hot. It sucks filling holes on a frames! Practice on some scrap of similar thickness for a while before you attempt it.
Old July 1st, 2010, 08:50 AM   #11
OldSlowReliable
extra on the SLOW
Oh, lol...I wasn't sure what you meant by the top edge... I get the ((( by using a sideways U and pulling instead of pushing (more comfortable )
Thanks for the tips, I have ALOT of welding to do, so I'll be able to try a few techniques
Sounds like a plan!
Old July 1st, 2010, 08:56 AM   #12
Nuggets
I fix stuff!
Nuggets's Avatar
I've been welding for years and I still can't make consistant pretty welds. My stuff holds together but it's defininatly not show worthy.
Old July 1st, 2010, 11:14 AM   #13
knaffie
knaffie's Avatar
Up always gives the best fusion. You can get away with down, but you need to move fast. Self-shielded flux-cored wire practically walks itself up hill. It would be worth it for you to grab some if you have a bunch of verticals to do.
Old July 1st, 2010, 02:43 PM   #14
OldSlowReliable
extra on the SLOW
I can get a good looking few in if everything is perfect...but otherwise its a no go
All I can use is self sheilding flux core! Lol, HF welder ftw ;)
Old July 1st, 2010, 09:29 PM   #15
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Welding vertical up from the bottom is going to be your strongest weld if done correctly. In fact it will be stronger than a flat weld if it is done right. Going down hill is not a real good way to do it.......will it work sure.............has it been done with success yes it has. Is it right.............most will say no unless you are running a root pass in some pipe with some P5 rod. With that being said do lots for up hill practice on some scrap and then go for it with a nice clean weld area. it will make your welds that much stronger.
Old July 4th, 2010, 08:43 PM   #16
OldSlowReliable
extra on the SLOW
They are all done..... both front legs went really well (have 3) on all sides....I made my gusset plates in a angled pattern (supposedly never weld perp to a frame edge) /___\ which helped ALOT to keep the puddle under control. I don't know why, but I had really good luck welding upside down....those were some of the best welds I've done! (minus the spatter hits)
However, on the rear legs, there was significantly more rust, so I had a really hard time getting clean metal, as well as reaching the top edge...If any of the welds are to break...it will be those.
Page generated in 0.57286 seconds with 71 queries
