Why Four Wires on my trailer brakes? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2010, 06:38 PM   #1
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Default Why Four Wires on my trailer brakes?
I'm in the process of fixing up my trailer. I'm not sure what brand it is but it's heavy, 2800lbs empty. On the back side of the backing plates there are four wires. Two of them go to the magnet for the brakes, the other two go to the spindle. Does anyone know why these two wires would go to the spindle?
A friend of mine that has dabbled in heavy equipment repair says that he's never seen anything like that before. I'm not sure who else to ask.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old June 30th, 2010, 07:15 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would assume the axle uses a ground? in the case of the backing plate the assembly would be a ground with power supplied to the magnet? so that being said they are probably static wires to prevent current draw through a bearing. if that were to happen they would arc even while turning and eat the bearing in a very short time.
Yetti
Old June 30th, 2010, 07:55 PM   #3
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
So I should hook three of the four wires coming from the backing plate to the ground?
Old June 30th, 2010, 08:01 PM   #4
Yetti
Yetti's Avatar
http://www.etrailer.com/faq-wiring.aspx
I am looking for an old diagram to show the wires. this is the best current site I have.
Yetti
Old June 30th, 2010, 08:23 PM   #5
jeepjk4dr
jeepjk4dr's Avatar
I've heard of this somewhere but I can't remember where. Thats so you can bring the power and ground to both sides by only running wires to one side. The two going into the spindle come out on the other side through that spindle. so on the side that your lead wires comes to, you hook up two to power and two to ground, then on the other side you just wire the two together. one set for power and one set for ground. Its all so you don't have to run a wire on the outside of the axel.
jeepjk4dr is offline   Reply With Quote
Page generated in 0.21652 seconds with 38 queries
