warn locking hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2010, 07:31 AM   #1
rangerluc
rangerluc's Avatar
Default warn locking hubs
i just picked up a d44 off an early bronco and itll be used for my sas in my ranger. ive never had the locking hubs, so can someone give me some info on them? when to lock them, when to unlock them etc...
rangerluc is offline   Reply With Quote
Old June 28th, 2010, 07:35 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Lock them when you plan on using 4wd, and unlock them during normal pavement driving. All it does is disengages the axle shaft to the hub.
If you have them unlocked, and you put it in 4wd, the front axle shafts will spin, but they will not provide power to the tires.
Depending on your transfer case, (if you can put the front in neutral) you can save a lot of wear/tear on your drive train by leaving the t-case in front neutral, and having the hubs unlocked. This means the front drives haft won't be spinning while you are driving.
Also, carry a spare, and know how to change them. The cheapo milemarkers and entry level warn lockouts are basically the fuse up front when you're beating up on the front axle. They break before anything else.
Page generated in 0.20040 seconds with 29 queries
