detroit EZ-Locker help UPDATE with pics! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2010, 10:43 PM   #1
Wehan
Wehan's Avatar
Default detroit EZ-Locker help UPDATE with pics!
I just put an EZ-locker in my dana 30 and it will only "lock" one side. the other side just spins and clicks, it refuses to engage unless I pry the center piece back over but as soon as I spin the tire by hand it disengages. I have tried turning the drive shaft with 1 or the other tire on the ground and the other up, no change, it just grabs the passenger side and lets the drivers side spin free. Do I just need new springs? (obviously this is a used unit, but all the teeth looked the same and seemed to have little to no wear.)
Wehan is offline   Reply With Quote
Old June 27th, 2010, 10:47 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Year, make, CAD?
Have u tried driving with it yet. It should engage when power is applied to the front driveshaft
Old June 27th, 2010, 10:58 PM   #3
Wehan
Wehan's Avatar
Was cad, just put 1 piece shafts in. it's in a 93 YJ. cant drive it yet, but it seems like it should lock up when I reef on the drive shaft with a pry bar and still only the pass side locks up.
Old June 27th, 2010, 11:04 PM   #4
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
It won't lock untill tourqe is applied from the front drive shaft. Get a friend to sit in the passenger side find some mud or gravel and punch it with the wheels straight, both tires should throw dirt.
lastmanstandin is offline   Reply With Quote
Old June 27th, 2010, 11:13 PM   #5
Wehan
Wehan's Avatar
OK. I was under the impression that it would act pretty much the same as my full detroit in the rear, that has no trouble locking both tires jacked up in the air and me spinning the drive shaft by hand. that whole "locked until wheel speed is sensed in a turn" thing kinda has me scratching my head at the moment.
Can someone that has an EZ-locker go jack up the axel it is in, and spin each tire by hand and see if one side is 100% free and the other side is engaged, and then verify that the locker is working properly?
I appreciate the help, but it just doesn't act like it even wants to engage even with a pry bar on the drive shaft moving the vehicle on the jack stands while my kid watches the locker do nothing (diff cover still off).
Old June 27th, 2010, 11:20 PM   #6
lastmanstandin
EvL 1
It's not the same as your full locker. It is like all the other lunchbox style lockers. It will not lock unless there is power being applied from the drive shaft. You don't have some dirt or mud you can test it in?
My lockrite is the same way...
Old June 27th, 2010, 11:24 PM   #7
Wehan
Wehan's Avatar
It has no driver side floor right now, so I guess I'll have to wait and see after I get my friggen first time home buyer $ back so I can fix the floor and then try it out in the dirt.
Old June 27th, 2010, 11:25 PM   #8
lastmanstandin
EvL 1
Damn that sucks.....
Old June 27th, 2010, 11:50 PM   #9
Wehan
Wehan's Avatar
yup, all well. Hope it works when I get to it.
Old March 30th, 2012, 08:15 PM   #10
Wehan
Wehan's Avatar
Update: i got the jeep driving again and went out on a gravel road and locked ot onto 4x4. I did a short reverse roast and was tossed to the side of the road. Sure enough, only the passenger side left marks. I did this 2 more times to confirm, only the passenger side is locking up, drivers side is free wheeling.
Old June 3rd, 2012, 10:08 PM   #11
Wehan
Wehan's Avatar
Update X2
Called Eaton and they said if my cross pin has flats on it i needed to replace it with one without flats. i pulled my axle apart and here are some pics.
Red is where the locker is making contact with the pin, yellow is the edges of the flats.
See anything wrong im missing? i can get more detailed pics if needed just let me know.
Old June 4th, 2012, 11:26 AM   #12
Outdoors
Field Repairs
Outdoors's Avatar
Did you reinstall the thrust washers when you installed the unit?
Outdoors is offline   Reply With Quote
Old June 4th, 2012, 11:30 AM   #13
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Is it with in spec?
H.o.r.e
Old June 4th, 2012, 11:54 AM   #14
Wehan
Wehan's Avatar
Yup thrust washers are installed. I didn't see any specs to check by in the install manual so i have no idea what/where to measure.
Old June 4th, 2012, 12:00 PM   #15
bigbchevy
missmrgreenagain
bigbchevy's Avatar
The gap in the middle of the two main plates has to be set to spec im not sure what spec is I don't have a book in front of me . But I would guess that to be the problem
H.o.r.e
Old June 5th, 2012, 12:43 AM   #16
Wehan
Wehan's Avatar
Thanks so much, i will get on the phone with eaton first thing and figure this out.
Old June 5th, 2012, 01:17 AM   #17
boggin-machine
boggin-machine's Avatar
I agree with scott. It appears to out of spec. Looks like the gap of the 2 side plates is to great. Iirc it's like 5/16s or less gap. Ill double check in the morning an post back.
Old June 5th, 2012, 02:45 PM   #18
Wehan
Wehan's Avatar
Well i called eaton and they basically told me there is no specs to measure and i should toss it on the trash because they don't make it anymore. But did say i can try shimming to bring the side plates closer together and did confirm that the flats on my pin shouldn't interfere.
Old June 5th, 2012, 02:47 PM   #19
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Order a spartan... Fixed my issue
Old June 5th, 2012, 03:12 PM   #20
bigbchevy
missmrgreenagain
bigbchevy's Avatar
More shims
H.o.r.e
Page generated in 0.32629 seconds with 83 queries
