need some info on replacing a rear waggy dana 44 wheel stud - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2010, 08:35 PM   #1
Marine_mike
SNSHTF
Marine_mike's Avatar
Default need some info on replacing a rear waggy dana 44 wheel stud
So I have a set of waggy 44s under my YJ. I had to remove the rear wheel to investigate a noise from the drum brakes..only to find a pebble or two. Well in the process of reinstalling the wheel (old chevy shank style lugs) I managed to break one of the wheel studs right off. I have the stud, but am unsure how to get the broken one out to put the new one in. Do I have to remove the shaft?
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old June 26th, 2010, 08:49 PM   #2
built
built's Avatar
Pound the old one out and if you can slide the new one through the back then you don't have to take the shaft out...
built is offline   Reply With Quote
Page generated in 0.15966 seconds with 29 queries
