Simplex Electric over Hydaulic pump - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2010, 08:19 PM   #1
JKOZ
yes
JKOZ's Avatar
Default Simplex Electric over Hydaulic pump
Simplex PES4032 pump
I've had it for a few years and just don't need it anymore.
This is not a light duty pump, it can take continuous usage if needed.
The pump new costs $3700
Located in Midland, MI
Works perfect - will guarantee that. Can do the sale through paypal - ebay if you prefer.
Asking $2k
Will ship for free in the lower 48 if I get $2k
this is the manufactures info
Suc-O-Matic feature reduces retraction time.
Two-speed operation provides fast advance.
Higher crossover for faster cylinder cycle.
Dual voltage 115/230 VAC 50/60 Hz Motor.
Motor starts under full load.
Runs reliably on 20 amp circuits.
Maximum amperage draw 17 amps at 115 VAC.
Adjustable relief for variable pressure settings.
Dual ports for easier plumbing.
Quiet running (80dBA).
SKU PES4032
Weight 73.0000
Manufacturer Simplex
Shipping Note: Ships from Cleveland, OH
Estimated Lead Time: If in stock, ships in 2-3 business days.
Volume per Stroke (cu. in.) LP 400 in3/min @ 1200PSI
Volume per Stroke (cu. in.) HP 55 in3/min @10,000PSI
Maximum Pressure (HP) 10,000 PSI
Oil Capacity (cu. in.) 2 Gallons
Oil Port (in.) 3/8" NPTF
Valve Type 3-way/3 Pos.
Valve Model Number VPS3 (w/Suc-O-Matic)
Valve Function Advance, Hold, Retract
Motor Type 1.5 HP, 115/230 VAC, 50/60 Hz, Single Phase
Max. Amp Draw 17 amps @ 10,000PSI
Number of Speeds 2
JKOZ is offline   Reply With Quote
Page generated in 0.13855 seconds with 26 queries
