Jeep d35 rear stock gears? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2010, 04:15 PM   #1
jeepgc96
jeepgc96's Avatar
Default Jeep d35 rear stock gears?
I'm new to this, I own a 96 Jeep Grand Cherokee Laredo. I want to put a lift in it and put some 33" mud tires on it, I'm guessing a 4" lift will work considering I already have 30" tires on it. From what I have read to maintain my fuel economy I will also have to change my front and rear ring and pinion. So my question is... How do I figure out what gears I already have in the front and rear? I looked in the door panel and the stock tires are supposed to be 215/75R15. I found a code on the rear axle that said 5251, but thats all I could find... So any info on how to figure this out would be nice.
jeepgc96 is offline   Reply With Quote
Old June 25th, 2010, 04:37 PM   #2
Jleach0696
Jleach0696's Avatar
In 1996, the 4.0L I-6 used 3.55 gearing in the axles, 3.73 for the towing package. To identify yours has the towing package, look behind the passenger side grille. If you see a mini radiator type item there, you have the towing group with 3.73 axle gears. Your Jeep will be equipped with a low pinion Dana 30 front and a Dana 35c rear.
If you have the 5.2 V-8, the axle gearing is 3.73. This would be equipped with a low pinion Dana 30 front and a Dana 44a rear.
took 2 seconds on google
http://wiki.answers.com/Q/How_do_cal...Grand_Cherokee
Jleach0696 is offline   Reply With Quote
Old June 25th, 2010, 05:47 PM   #3
jeepgc96
jeepgc96's Avatar
I tried google but I guess I didn't type in what I should have, I have the I6 and I don't believe I have the towing package so it must be the 3.55 gears. Thanks.
Old June 27th, 2010, 09:14 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
You'll need more than that to fit 33" tires. I have about 8" on my 96 and run 33" tires with no rubbing at full flex.
If you're willing to trim then you might be able to get away with it.
Page generated in 0.20034 seconds with 35 queries
