383 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2010, 09:37 AM   #1
88K5Blazer
Team Misstress Mud Racing
88K5Blazer's Avatar
Default 383
Will the stock crank and rods from a small block 400 work to start on my 383 or do i need different length rods also can i build one using a tbi block and one more if i change the intake on my tbi motor and run a carb can i still use the stock distributor thanks
88K5Blazer is offline   Reply With Quote
Old June 25th, 2010, 10:03 AM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
You also have to bore is .030 over to get a 383, if you don't you'll have a 377. As for rods, long is better! http://www.chevymania.com/chevymania/tech/rod.htm. You can't use a tbi block, and I'd switch to carb rather than tbi. Yes the distributor wont work either.
Old June 25th, 2010, 10:13 AM   #3
AFRd_CJ5
AFRd_CJ5's Avatar
Honestly, you're probably better off buying a stroker crank from Summit/etc. By the time you get the machine work done on the 400 crank to make it work, you're still using an old used crank, and you probably have just about as much $ into it that a new one would be.
AFRd_CJ5 is offline   Reply With Quote
Old June 25th, 2010, 10:28 AM   #4
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
I thought the 400 crank had to be machichned to fit in the 350 journals?
Old June 25th, 2010, 10:54 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can't use a 400 crank in a 350 block unless you get it turned to 350 journal size. you can't use a 400 crank in a 87 and newer TBI block due to the newer 1 piece RMS. you can however use 400 rods if you want to retain stock 350 pistons. you can't use a TBI distributor on a carbed engine it will run like shit without the electronic inputs. the advance curve is based off TPS, coolant temp, map pressure among other things.
Page generated in 0.19222 seconds with 38 queries
