Rear 6 lug rotor suggestions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2010, 06:12 PM   #1
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
Default Rear 6 lug rotor suggestions
im ordering chevy 6 lug axle shafts for my ford 9" rear end and need to find rotors to put in it...what vehicle would have the deepest offset rotor that would slide over the axleshaft? im using 96 dodge 1/2 ton rotors now and the bracket had to be weld so close to the flang that 2 of the bolts wont come come out of the flange if they were to break bc there isnt very much offset. im goint to be using the Standard Chevy 1/2 ton front calipers.
MJ_Silver_1988 is offline   Reply With Quote
Old June 22nd, 2010, 08:59 PM   #2
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
something off of a newer chevy 1/2 ton like an 2004 Silverado. the rear rotors should work for you.
spr_chicken is offline   Reply With Quote
Old June 22nd, 2010, 10:34 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
x2. 99 and newer up til 05 had rear disc. they offset in quite a bit.
Kodiak450r is online now   Reply With Quote
Old June 23rd, 2010, 10:22 AM   #4
liftedandgifted
liftedandgifted's Avatar
There are two different rotors. One's for the trucks and ones for the tahoes/suburbans. One is deeper than the other by a few mm. Hope this helps.
Carquest or auto Value part numbers
55066 325mm diameter x 85mm deep from flange
55084 330mm diameter x 90mm deep from flange
liftedandgifted is offline   Reply With Quote
Page generated in 0.22124 seconds with 35 queries
