axle math - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2006, 11:06 PM   #1
Mongo
Mongo's Avatar
Default axle math
Ok 1978 corp. 10 bolt
I'm trying to figure out what gears
I counted the ring and pinion and came up with 40 and 12(I think, I was under attack by a swarm of Africanized killer skeeters).
The math says 3.33 but I've never heard of that.
Just in case...
1978 1/2 ton 4x4
350/350 auto
rear is a 12 bolt
to my knowledge, original gears
Craig
Mongo is offline   Reply With Quote
Old August 9th, 2006, 09:31 AM   #2
PavementPounder
PavementPounder's Avatar
The numbers should be on the side of the ring if you rotate it. You probably counted wrong and its 41/12 = 3.42, which is a common Chevy ratio.
Cliff Notes = You suck at math.
if you want an extra 12-bolt for shafts/brake hardware, I have a complete 3.08 for $50.
Old August 9th, 2006, 09:43 AM   #3
Yep, just count again. Use something like a grease pencil to mark the starting tooth, and every 5th tooth or something, to keep track.
And as mentioned, with a chevy axle, you will probably come up with something like : 3.08, 3.42, 3.73, 4.10
Page generated in 0.24354 seconds with 32 queries
