01 RM 250 Power Valve - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2010, 07:25 AM   #1
dreezy
Haggard Fab
dreezy's Avatar
Default 01 RM 250 Power Valve
The actuator rod came out of the hole that it goes into and its been a bitch trying to get it to clip back into its a hole. I know this is a shot in the dark but is there a was to get it back in where it goes without pulling the side of the motor off or am I screwed into taking half of the bottom end apart to clip it back in?
Here is a diagram of what I'm working with, it is the K1 model.
http://www.bikebandit.com/2001-suzuk...m6589sch258245
Any help would be very appriciated. Im trying to get this thing set to go to the dunes the week before the 4th of july.
Old June 17th, 2010, 07:54 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
should just be the side cover and waterpump - the clip may be broken and need replaced anyway. Honestly - shouldn't take an hour to fix.
@clarkstoncracker
Old June 17th, 2010, 08:00 AM   #3
dreezy
Haggard Fab
dreezy's Avatar
I thought about pulling the pump out last night to see if I could get at it. For some reason I didn't. Appriciate it.
Old June 17th, 2010, 08:03 AM   #4
jeepinRRT
jeepinRRT's Avatar
^ This
If it anything like a honda of the same vintage there will be a small collar and cotter key holding the arm in place. This is all located under a dedicated cover, two or three bolts at the most.
jeepinRRT is offline   Reply With Quote
Old June 17th, 2010, 09:07 AM   #5
dreezy
Haggard Fab
dreezy's Avatar
Originally Posted by jeepinRRT View Post
^ This
It apears to be just a plastic clip that I am sure is worn out if not broken like ScOoTeR suggested. It is for sure connected at the arm on the valve though.
Which brings up another thing. In trying to get the arm connected it apears the valve got stuck open and it won't close. Does the bike need to run to have this shut or am I stuck with another problem. It was too late last night to fire it up to see.
Old June 17th, 2010, 02:50 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
All exhaust valves are operated by centrifugal force and depending on the setup - the assy will not move unless it is spinning pretty fast. The KX we have won't move because there are parts in the way the spin out of the way when it's running.
@clarkstoncracker
Old June 17th, 2010, 02:59 PM   #7
dreezy
Haggard Fab
dreezy's Avatar
With the Power Valve side cover off, I could rotate it its full range of motion by hand. Now the shaft will only rotate about an 1/8 of a turn to wide open and wont return to closed. Talking with a guy at work he thinks its carbon build up, but it was opening and closing freely.
Old June 18th, 2010, 06:05 AM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Shit.
Carbon would limit motion, depending on your premix of choice, but if you could move it freely before, sounds like something in the linkage is binding. Sucks you're on the other side of the state.
@clarkstoncracker
Old June 18th, 2010, 07:02 AM   #9
dreezy
Haggard Fab
dreezy's Avatar
Shit.
Carbon would limit motion, depending on your premix of choice, but if you could move it freely before, sounds like something in the linkage is binding. Sucks you're down by STL
Fixed. I will tear the top end off it again off it again this weekend and see what that f is up.
I had been running Klotz benoil in it. I know it isnt the greatest for a bike with a pv, but my atk didnt have one and I had a bit of it left over. I dont know what the previous owner used. He either had no clue, or played me pretty good. This bike has been a bit of a headache.
Old June 21st, 2010, 04:09 PM   #10
dreezy
Haggard Fab
dreezy's Avatar
I got it apart and back together on saturday. The clip was still in one piece and it snapped right in. Its amazing what new rings, a re-packed muffler, new air filter, oh and removing a huge ass weight from the flywheel did to wake this thing up.
Page generated in 0.23304 seconds with 53 queries
