Weird creaking? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2006, 06:06 PM   #1
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Default Weird creaking?
Just wondering if any other of you 94-01 Ram owners have had this issue. I get this creaking from the rear of my truck. I can't pinpoint it.
At first it sounded like just the bed flexing on the frame, but after getting underneath of it and yanking on stuff, it sounds more like it's coming from either the leafs themselves, or the blocks on the axle. If I push up on the frame, it'll make the sound once even if I continue to jounce it upwards from a resting position. If I then pull down, it'll make the sound once even if I continue to yank downwards from a resting position. That really makes me lean towards suspension.
Any input?
Old August 8th, 2006, 06:40 PM   #2
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
i know on earlier rams, they had that noise from the shackles...
Viperdave is offline   Reply With Quote
Old August 8th, 2006, 07:37 PM   #3
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
look at your shocks for any leaks or just sings of old age. Monroe suggests shocks be replaced every 50,000miles just for ride performance and handling.
Spence1986 is offline   Reply With Quote
Old August 8th, 2006, 07:57 PM   #4
GreaseMonkey
Pew pew!
Definately not the shocks, the shackles are a definite possibility.
Old August 8th, 2006, 10:07 PM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
grease the bushings they get creaky and clunky.. Also you can jack the truck up by the hitch to spread the leafs and spread anti seize in there.
Old August 8th, 2006, 10:08 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Prob. bushings
Old August 8th, 2006, 10:31 PM   #7
GreaseMonkey
Pew pew!
Grease the bushings on the shackles? Didn't know they were greaseable.
Thanks B.
Old August 9th, 2006, 08:17 AM   #8
KILLER"B"468
Yankabilly
Thanks B.
pull the bolt, put grease in hole, put back in. I had to do that to the blazer. They don't move much and rust in place. start to make noise when stuff gets in the way when they do have to move.
Old August 9th, 2006, 09:17 AM   #9
PavementPounder
PavementPounder's Avatar
If you're going to go through the trouble of pulling the bolt anyway, consider buying a greaseable bolt to replace it with.
Old August 9th, 2006, 09:44 PM   #10
GreaseMonkey
Pew pew!
I couldn't pull the bolts completely out. I don't even know how the hell you would swap out leafs when the bolts back straight up into the frame. They would go about halfway out, shot some white lithium grease in there.
It was still creaking after that. Then with a floor jack and about 5 blocks of wood (it's a bit far off the ground), I jacked the rear up underneath the hitch. I then shot some anti-seize inbetween the leafs as best as I could. That seemed to take care of the big creaks.
Then I was hearing smaller creaks from the tailgate. Dropping the tailgate and jouncing the bed they went away. So I lubed up all the tailgate rubber isolator thingies, hinges, pins, etc.
Noise seems to be gone....fawkin' Dodge.
Old August 10th, 2006, 09:21 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
Which bolt could you not get out ??
You have to remove the lower bolt before u can have clearance to get the other one out... ( insert pp comment here ( Yea Mr. ASE)) :tonka: :tonka: :tonka:
Old August 10th, 2006, 09:36 PM   #12
PavementPounder
Oh
STHNAP
Old August 11th, 2006, 06:29 AM   #13
GreaseMonkey
Pew pew!
Your right...but I also really didn't feel like removing my trailer hitch to do this either, Mr. Midas.
Old August 11th, 2006, 10:49 AM   #14
Mclovin
"The Situation"
Mclovin's Avatar
you have to pull your hitch to get the shackle bolt out ?? that sucks !
Oh and Wrong again bitch, i be chillin at the Holiday Inn
Old August 11th, 2006, 04:16 PM   #15
GreaseMonkey
Pew pew!
So now you just think you're smart because you work at a Holiday Inn Express?
Old August 13th, 2006, 01:07 AM   #16
Mclovin
"The Situation"
Mclovin's Avatar
Nope, but i am a lot lazier now..
Page generated in 0.26790 seconds with 71 queries
