HP D30 help. lockrite wont come out... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2010, 12:38 PM   #1
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Default HP D30 help. lockrite wont come out...
Ok I want to take the lock right out of my D30. I went and pulled a carrier with the spider gears from a HP D30 at the junk yard. Can I just switch the ring gear and install the new carrier in my axle? Will I need to do anything special to make sure the ring gear is in the right position? Thanks for the help.
lastmanstandin is offline   Reply With Quote
Old June 16th, 2010, 12:41 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Just put the spider gears from the new carrier in the current one that is in the Jeep.
Take out Lock-Right
Put in spiders
Old June 16th, 2010, 12:42 PM   #3
MiNi Beast
MiNi Beast's Avatar
you do not need to even pull the carrier, all you need to pull in the center pin and swap spider gears in, pretty simple, then hang on to the locker for me when I come down.
Old June 16th, 2010, 12:43 PM   #4
BigBlockBlazer
Axle breakin' 101
The ring gear must come off to take out the pin. Pull carrier.
Old June 16th, 2010, 12:46 PM   #5
MiNi Beast
MiNi Beast's Avatar
yeah 10-4 thinking rear,
Old June 16th, 2010, 12:48 PM   #6
lastmanstandin
EvL 1
Take out Lock-Right
Put in spiders
Ya to get the spring pin out the ring has to come off, thats why I was wondering if I could just switch rings and slide the new carrier in so I don't have to do all that.
Sorry Mini I'm going to be tradeing the locker for a CAD or hub axle.
Old June 16th, 2010, 12:52 PM   #7
BigBlockBlazer
Axle breakin' 101
You have to pull the carrier anyway, it's only 15 min on the bench switching parts. That way you know the bearing setup is right.
Old June 16th, 2010, 01:02 PM   #8
lastmanstandin
EvL 1
Ok thats what I needed to know. I'll just switch out the spiders on the original carrier. Thanks.
Old June 16th, 2010, 01:34 PM   #9
PavementPounder
PavementPounder's Avatar
No. If you disturb the ring, you must perform another gear set-up.
Old June 16th, 2010, 01:43 PM   #10
lastmanstandin
EvL 1
what? The ring has to come off to get the pin out that holds in the center pin. So no matter what I do I'll need to have the gears set up? That sucks ass. I was just going to mark the gear and carrier and use the marks to line them back up when I was done...
Old June 16th, 2010, 01:45 PM   #11
PavementPounder
I meant from carrier to carrier. If you take the ring off the carrier with the locker to put it on the open carrier, you would need to perform a set-up.
Not if you mark it like you describe and put it back together on the same carrier.
Old June 16th, 2010, 01:48 PM   #12
BigBlockBlazer
Axle breakin' 101
Do it as you described and it will be fine. No need to setup gears again.
EDIT: PP beat me to it...
Old June 16th, 2010, 04:13 PM   #13
lastmanstandin
EvL 1
Om cool deal. Thanks guys. I'm gonna do it as soon as I get home!
Old June 17th, 2010, 07:28 PM   #14
lastmanstandin
EvL 1
Well i got it apart and can't seem to figure out how to get the locker out. Any ideas? I'm going to try and find some install directions on line...
Old June 17th, 2010, 09:12 PM   #15
GREASYHANDS
GREASYHANDS's Avatar
Using a 90* pick pull the little springs out and then the pins will slide down when all springs are out and the pins are in respective holes it will come out in 4 pieces
Old June 17th, 2010, 09:17 PM   #16
lastmanstandin
EvL 1
Thankyou once again, came out fairly easy. Getting the spider gears to line up with the holes in the carrier was a different story! I'll get it all back togeather in the a.m. and see if the poping snapping sounds are gone.
Old June 17th, 2010, 09:26 PM   #17
jeepnxj96
jeepnxj96's Avatar
Just a heads up looking at your pics, make sure you hose those bearings out pretty good with brake clean to get the dirt and other garbage out, don't want to smoke'm first wheeling trip out
Page generated in 0.43204 seconds with 74 queries
